SOURCE: Stihl FS 85 stalls and wont start after about 20
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
b\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
285
7772400
10058400
259
261
257
280
262
283
06WOHFQ%ZQT6,!3GM2\Y["P
5
286
False
0
0
-1
304800
243
True
128
77
255
3175
3175
70
True
True
True
True
True
282
134217728
-9999996.000000
8
Empty
16711680
52479
26367
13421772
16737792
13382502
16777215
Bluebird
-87325200
-87325200
267
263
5
No. It sounds a too simple, but try this: The next time you run it and it starts to die, loosen the gas cap. It should start to run again. This means that the gas cap is clogged up with dirt. It is not vented properly, causing the carburetor to not get gas.
Jim
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
SOURCE: I NEED A COIL FOR STIHL FS 220
part number 0000 400 1306 lists at $105.00 and any Stihl dealer can order it for you
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
