A
Anonymous Posted on Nov 16, 2018
My epson lx 350 double images when printing what is the problem and solution
Pensivania Pensive
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Nov 19, 2018
Pensivania Pensive
Expert
Level 2:
New Friend:
Answers
66
Questions
0
Helped
56917
Points
177
Push peper buttom and switch on.
Machine print quide.
You make it.
5 Related Answers
Anonymous
  • Posted on Dec 03, 2007
SOURCE: Epson LX-300+ Matrix Printer Problem
Please change the setting print direction from bidirection to unidirection.
Anonymous
  • 88 Answers
  • Posted on Mar 29, 2008
SOURCE: printed lines shift to left and double images
Are the lines vertical? Have you tried to align the printheads? This can be done using your printer's installed maintenance software.
hashchathy
harsha gayan
  • 246 Answers
  • Posted on Nov 07, 2008
SOURCE: problem with the epson lx 300
Try to reinstall the printer diver
Anonymous
  • Posted on Feb 20, 2009
SOURCE: Poor print quality of pdf documents on Epson LX-300
PDFs are designed to print using Postscript language.
The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
This has worked well for me.
Jonnhzz Chan
  • 186 Answers
  • Posted on May 23, 2010
SOURCE: epson lx 300 + # print not readable
if the print out is not readable.. most probably your print head pin is broken.. you can check your print head by removing it.. just unscrew the screw holding the print head and look at the front portion of the print head..over there are rows of pin.. see if the pin is even else it's broken..
My epson lx 350 double images when printing what is the solution
Check inside the machine to see if there is a small quantity of paper crammed into one side or other. This would change the positioning of the left and right calibration points. Remove anything that doesn't belong and then perform a print alignment .
1helpful
2answers
Driver for epson fx 350 printer?
Go to printer manufacturer website for driver.
1helpful
2answers
How to change the font size of epson lx 350?
The font is determined by the document setting. Or you can check the PROPERTIES tab after you select PRINT.
2answers
My epson px660 is photocopying and printing double images
Try to print with disabling high speed option. Check the linear encoder. Clean it if dirty.
Epson LX 1170. the print on the 4page of the
If you make the XX copies and his is too light the problem is in the developer station.Check or changeb the developer,image photoconductor,photoconductor cleaning blade.Or make the AUTOMATICAL IMAGE DENSITY LEVEL CONFIGURATION.
6helpful
1helpful
Print quality is very poor
I used to use an LX300 and have never had this problem. I'm not sure what unclear means so I will just do some guessing. Clarity of the print depends on 3 things, software, printhead and ribbon. These are your problem areas. Epson has an option to print NLQ or near letter quality. So that should give more clarify. I basically double prints the same letter to create a darker image. The printhead, if your printer is really old, you need to either find someone to refurbish the printhead or buy a new printhead because it could be the impact pins are bent and not giving the strongest image. Lastly the ribbon, obvsiously the more used the ribbon is the weaker the image. So either re-ink the ribbon or buy a new ribbon cartridge. Hope this helps.
Printing shows doubling
alguien por favor envieme los drivers de la impresora EPSON LX300 les agradesco
8helpful
5answers
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
