Question about Sanyo Air Purifiers
How to reset my sanyo air purifier? unplugged to clean, but wouldnt power back up
SOURCE:
  • 14 Answers
SOURCE: reset filter
The solution is simple. Just press on the little red light that says to reset filter. Its a button that will reset the warning and the light should go out
Posted on Dec 02, 2007
SOURCE: Sharper Image GP Silent Air Purifier with Ionic Breeze s1730
i have 2 units, and had this same issue happen 3 times. Tonight it happened with a forth, last time i had to talk to management to get it replaced outside of warranty. Ionic breeze has major quality issues, and I would NOT buy anything else from sharper image. They also reduced the warranty from the original model drastically. for the price these were, they should be covered lifetime to show their commitment to their product. there is also a class action lawsuit against sharper image, for their false claims for the product...i believe sharper image chose to settle.
Posted on May 31, 2008
SOURCE: sharper image quadra silent air purifier has red light flashing
Have you cleaned the bars lately? I believe that red light means that the bars that collect the junk from the air are at capacity and needed to be wiped down.
If you don't know how to do this, pull them out from the top after having turned the machine off. Get a rag or paper town moist, but not dripping and just wipe the black soot off all visible sides of the metal bars. Lay it aside when done over night for it to dry completely, then re-insert them into the machine. Turn on and hopefully that should take care of it!
Posted on Jul 12, 2008
SOURCE: ecoquest air purifier
i have a ecoquest, what you need to do is push the reset button AFTER cleaning. and the preform cleaning will go away.
Posted on Sep 05, 2008
SOURCE: Homedics AR10 Air Purifier - Clean filter light issues
Please do search before asking question. This one was answered only 20 days ago: http://www.fixya.com/support/t10714206-need_reset_homedics_hepa_air_cleaner
Posted on Nov 26, 2011
Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
Hello, this is Ava with Think Crucial.
Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 24, 2016 | Hunter Air Purifiers
Fresh Air Maachine by Ecoquest
I've read from some other posts on here that Ecoquest is good about returning the items and replacing them.
Jul 12, 2008 | Ecoquest Fresh Air Air Purifier
Eco Quest Fresh Air
Have you unplugged it? Or is there a hard reset for it other than the reset button? Can you try to hold the power button down and see if that does anything? But try to pull the filter and stuff out again, after you have unplugged it, see if that works.
Mar 15, 2014 | Ecoquest Air Purifiers
My Fresh Air Eqo Quest shut off yesterday and I can't get it to go back on. I have hit the reset button, I unplugged and replugged, I even cleaned everything. It won't turn back on. Is there a...
There is a fuse in where the AC cord plugs into the purifier. Remove the back cover, and you should be able to remove the fuse by prying the fuse cover off with at straight screwdriver. It takes a 1.6 amp fuse for 120Volts
Jun 06, 2011 | Ecoquest Fresh Air Air Purifier
I want to take my ecoquest fresh air apart to clean it, but do not know how, i have misplaced the manual
Unplug the machine and unscrew the phillips head screw on the back grill of the machine, that is just above the plug. There are depressions on the sides of the back grill that has a plastic tang that hold the back grill to the machine. Press the back grill inwards to allow the tangs to clear the sidee and the back grill should now be easily removed. Remove the two thumb screws on the top corners to remove the filter. Once the filter is removed, then you can remove the purification plate and remove the two screws that hold the RCI cell. The RCI cell and filter can be cleaned by vacumming out the dust and dirt.
The purification plate can be cleaned with a old toothbrush and a water and amonia solution. Scrub the metal grid with the toothbrush. Do both sides and then rinse with water, allow it to dry completely before reinstalling the plate. After every part is cleaned reassemble the purifier, and plug it in. Then press the reset reminder button on the front of the keypad to clear the "perform cleaning" message. This message will appear again after the purifier runs for 30 days to remind you to clean the purifier. Hope this helps you.
Oct 09, 2010 | Ecoquest Fresh Air Air Purifier
I placed the filters back in , but the clean red light is still on. this is an ionic pro compact cleaner
Try unplugging it, for a few minutes and wait then plug it in again and see if it resets.
Otherwise you need to reset it.
Most appliances that displays warnings have to be reset after it is corrected.
even your trusty automobile check engine light.
good luck.
Jan 30, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Pure Ion will not turn on. We took out the filters to clean them. Wall outlet works for other items. Have tried other outlets.
It sounds like the main board is not getting power. The power supplies have capacitors inside that do overheat and burn out. You can test power coming from power supply leading to main board with a voltmeter. You can try to unplug for 8 hours, in meantime while unplugged, press and hold power button for 5 seconds, then wait 1/2 hour and plug back in to see if unit has reset itself
Oct 13, 2009 | Brookstone Pure-Ion UV Air Purifier
My sharper image air purifier cleaning light comes on
Can you clarify the problem.. all I can see is
"My sharper image air purifier cleaning light comes... when it is clean"
The light that informs you that its in need of clearning comes on even though it is clean?
make sure the purifier is completely clean and reset it by unpluging it from the powersource for 30 minutes, the manual may include a reset process which might fix the problem.
Nov 28, 2008 | Sharper Image Professional Plus Ionic...
Clean button
My ionic pro did the same, the red light just wouldnt go out, so I looked down the plate opening, (with unit unplugged), and could see one of the wires was broken. (these are the ones you clean by pulling up that plastic tab). I am currently looking for replacement wires, will post my progress. GregV
Oct 10, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Air Purifiers Logo
149 people viewed this question
Top Sanyo Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Sanyo Air Purifier Expert? Answer questions, earn points and help others
