SOURCE: morphy richards steam generator model 42271
is there a noise when u press the trigger? if not there is sometimes a reset button on the front of the base. failing that the problem may well be the solenoid which opens to let the water into the steaming tank which is repairable but can be awkward.
SOURCE: safety switch keesp coming on ! Morphy richards
The safety switch is normally a motion sensor , it should only come on when there is no motion and the iron is face down. Try shaking it up a bit as it has a moving ball inside that detects the motion. Failing that it would need a motion sensor replacement or calibration. Regards PSP
SOURCE: Morphy Richards AC925EYG Convection has stopped heating items
Same thing has happened to me. My brother in law seems to think it cant be fixed. Bought it Dec 2008 so no warranty.
Were you able to get anythihng out of morphy richards?
SOURCE: Hi there Hiw can I turn off the whistle on the
You can turn off the electronic whistle on the morphy richards kettle by moving the switch (marked with a musical note) which is located underneath the electric base unit (not on the kettle itself).
SOURCE: MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
