SOURCE: straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
SOURCE: Blade Alignment?
ok yep your blade is out of alignment with the fence. It is closer to the fence at the rear than the front. You need to make the modification or adjustment to your fence, if it allows that, and then worry about the miter slots later (which should be adjusted miter slot to blade, not miter slot to fence). You might be able to adjust the miter slot to blade by moving the actual table and then securing witht he table mount bolts. Check your manual for how to align the fence.
You do want to fix that though as it can be potentially dangerous and result in kickback of the workpiece which is a rather SCARY thing, and very dangerous.
SOURCE: Band saw blade wanders.
cut freehand. A bandsaw blade will always run off to one side or the other, even using a fence.
The rip fence is intended for re-sawing only, and very thin strips
SOURCE: Ryobi WS720S wet tile saw. Will not spray
Check the pump operation and pump intake screen for plugging. Make sure the water reservoir is not full of cutting debris.
