Question about Sanyo Refrigerators
I'm looking for racks and crisper for a Sanyo mini refrigerator. This product is no longer available but I'm hoping someone can direct me to where I can find them or replace them. model SR3700
    Top Expert:
  • Sanyo Master
  • 62,106 Answers
    Top Expert:
  • Sanyo Master
  • 6,289 Answers
Check ebay if you have part #.
Posted on Nov 14, 2018
SOURCE:
  • 4234 Answers
SOURCE: Looking to replace lost remote
The Sanyo part number is: 6450656934
It used to cost about $25, but is no longer available from the distributor I use. Hopefully the part number will help. Realize that most universal remotes should work just fine. Just be sure to get one that has a menu button.
Dan
Posted on Jul 15, 2008
solveditnow
  • 39 Answers
SOURCE: Maytag dishwasher model #PDB3600AWX prongs rust & disintegrate
Getting a replacement set is not hard www.partselect.com has the part. If you don't want to spend the money you might try scraping the rust off of the prongs and then use a high temperature rated epoxy product to dab a new covering over the exposed steel. That might last for awhile. I'm guesssing. I think it needs to be a covering that can stand high temperature with a rating of at least 200 degrees or better and a chemical and humidity resistance rating. An electrical conductivity rating and thermal conductivity rating are not required. Its a patch but it might work Ok. I don't think the rust will get on your bottles but the prongs will weaken and break after awhile so if you can stop the rusting that will help you get more life out of the racks.
Posted on Jan 14, 2009
milten1
  • 1304 Answers
SOURCE: Hi, I'm looking for a part for an Amana
according to
appliancepartspro.com
they show your whole crisper assembly
is available
Posted on Oct 13, 2009
  • 5603 Answers
SOURCE: Hellow, hope you're having a
I would investigate a fan that circulates the air from freezer to the rest of the refrig.
ALSO investigate the door seals. This is a very common problem. Slide a piece of paper around the door to insure there is no gaps in the seal. The hinge settings and door fitup are important.
Posted on Mar 12, 2011
AndrexT
  • 26432 Answers
SOURCE: SR6908X Sanyo mini Refrigerator manual
this is probably close enough?
No exact matches found Showing results for sanyo sr
Posted on Nov 08, 2016
Where can I find a SR-4910M user's manual for this Sanyo refrigerator?
10 years old. About 50 bucks. I found this
Waste of money
Review by mamacat57
October, 14 2005
  • Pros: Attractive
    Cons: Thermostat, approximately 1/5th of the unit price is a weak link.
    This refrigerator broke within 14 months. Our primary use was as an overflow unit for soda and produce, therefore it wasn't subject to a lot of abuse. Sanyo was VERY unhelpful when we contacted them for assistance, basically blew us off because it was out of warranty.
  • Oct 28, 2015 | Sanyo SR-4910M Compact Refrigerator
    Why are vegetables freezing in crisper?
    There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
    Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
    Hi! How do I find Sanyo compact ice storage replacement door? Thanks!
    I'm assuming that your asking about a freezer door on a compact refrigerator. parts can be ordered on line @ sears direct, go to link below & enter model # or scroll down page & select refrigerators under, find parts by top product categories - scroll to refrigerator brands found - select Sanyo refrigerator parts - scroll down & select your model - select View all parts in this diagram, some parts will be available others you will have to call phone # provided. when looking @ your parts list there will be a exploded view on left ( to see it better click on view full size) http://www.searspartsdirect.com/partsdirect/brands-products/Sanyo-Parts/Refrigerator-Parts
    Aug 18, 2014 | Sanyo SR-4910M Compact Refrigerator
    I need a glass shelf for the crisper drawers 22 5/8
    The glass shelf is no longer available but having someone cut glass to size will work, Thanks Sea Breeze
    Nov 19, 2012 | Refrigerators
    We have a GZ2727GEHBS model Maytag refrigerator and the bottom Fruit & Veg Fresh Crisper is broken. The local agent syas that Maytag do no longer manufacture the necessary spare part and has provided a...
    Hello gmcg474,
    I understand that you are having a problem locating a new crisper for your Maytag Refrigerator. I have located a crisper but do not know if it is the same as the one you are looking for by cross referencing this is the only one available that will fit your unit and all others have been discontinued. Here is a link to three IMAGES of the unit located at Partselect.com
    Thank you for choosing FixYa.com
    Jusinbur167
    May 17, 2011 | Maytag Refrigerators
    Broken crisper rack
    you can get one from about any appliance parts store just call with your model number
    Feb 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
    Glass shelve on bottom over grisper is broken Sanyo SR-9510W
    You didn't say what size or model Sanyo you have, but the solution is easy. I have a Sanyo under the counter refrigerator in which the glass over the crisper is 1/8" thick frosted glass, 16" by 6 3/4" with the two back corners cut off diagonally. The frosting is simply to prevent you seeing through into the crisper below. It is maybe fifteen minutes work with a piece of window glass and a glass cutter to make a replacement. My full size refrigerator uses 1/4" glass since it is much larger and I have replaced it myself this way. If you don't have a glass cutter -- they are cheap and available in all harware stores -- you should be able to get any hardware store to make the cuts for you. They are accustomed to making custom cuts for people replacing their own windows. The have, and I use, what is known as an oil cutter which is a lot easier to use than the little hardened steel wheel cutters you will get if you buy a cheap one. Those work fine for straight cuts. Oil cutters make curver cuts equally easy to do.
    Dec 07, 2008 | Sanyo SR-9510W Refrigerator
    Looking to replace lost remote for Sanyo TV Model #DS20425 can you direct me for replacement
    Dan
    Jul 15, 2008 | Televison & Video
    Refrigerators Logo
    51 people viewed this question
    Top Sanyo Refrigerators Experts
    Marvin
    Marvin
    Bailey's...
    Bailey's...
    Albert Nairn
    Albert Nairn
    Level 1 Expert
    Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
