Question about Sanyo Televison & Video
Sanyo tv FW42D25T has sound and ghost like picture
Check input or source setting
4 Suggested Answers
SOURCE:
jingjao
  • 252 Answers
SOURCE: SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Posted on Oct 10, 2008
SOURCE: my sanyo tv has no picture no sound 31"color tv
my grand son unplugged my sanyo tv 32in from wall while on no wi have no picture and no sound
Posted on Aug 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: sanyo lcd tv 20"has sound but no picture
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks! ! ! !
Posted on May 27, 2011
Sanyo,LCD tv, Model DP55D44.
First thing I would try is replace whatever cable you are using for the input. Or just turn the TV on and press the input/source button on the remote then move the input to see if you get anything different.
Aug 08, 2016 | Televison & Video
BLANK SCREEN..NO SOUND OR PICTURE ON MY SANYO 50" FLAT SCREEN TV...MODEL NO: DP52440 HOW DO I RESET IT
Try unplugging the set from its power source, let it sit for 10 minutes and then plug it in again, then turn it on. Are you getting any on-screen messages or logo display when you turn it on? Is there any backlighting showing? (in a dark room, the screen should have a faint glow). Try switching the input source using the remote. If the set is less than a year old, it is under warranty. If nothing is displayed ever on screen, the panel might need repair or replacement.
Jan 28, 2015 | Sanyo Televison & Video
My Sanyo DP42647 TV has sound but comes in very fuzzy not clear at all
have you checked it on video inputs on rear of set and also on tuner inputs to see if problem on all inputs?
Aug 26, 2012 | Sanyo 42 in. LCD TV
My sanyo was working fine, then a child hit a button and now it says no input signal sources could be located how do I fix this
The TV has different inputs modes, the TV tuner being on of them, another mode(s) will accept an input from the input jack(s) on the back, front or side of your TV. Look for and source button or input button on the front of the TV, press it waiting a few seconds between each push until the picture returns.
Jun 19, 2010 | Sanyo DS27910 27" TV
Loud buzzing sound on Sanyo AVM 1909
I had a problem like that so I disabled the tv's onboard tuner (input source)and now we use the cablebox's video and audio out to the video and video in jacks on the TV this will work as long as you have a cable box or sat reciever for your video and audio source and of course your TV must have video and audio inputs so it will work.
Good luck Rich
Jun 06, 2010 | Sanyo AVM-1909S TV
Picture set up seems really weird n i get a lot of ghosting?
sound like you have an input issue. if tv looks great on some channels and dodgy on others, could be cable or sat box issue. checking with your tv provider and schedule a service call. have them check connections and download speed from box to the pole. would also check a different input like a dvd or game console to verify problem. i would also google search your area for people with similar problems with same TV service as you. hope this helps, J
Apr 07, 2009 | Televison & Video
Don't know where the antenna input is on my tv
You can download the manual for this TV from Sanyo here:
http://www.sanyotv.com/CLT2054%20(E)%205071--.pdf
It has all the hookup information for you.
All the input jacks are on the rear of the set, and they are pretty clearly labeled.
You can connect the converter box two ways. One is to use the RF output from the converter to the antenna input on the rear of the TV. Then set the TV to channel 3 or 4, depending on the converter box setting.
The second method, which is better, is to connect the direct video and audio outputs from the converter box to one of the TV's A/V inputs. The cable you need is usually supplied with the converter box. Just follow the color-coded jacks at both ends: red and white for right and left channel audio, yellow for video. Then set the TV to that source. This will give better quality picture and sound from the box.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Feb 07, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Ds31590
njdb,
Look on the remote for keys that are labled tv/vcr or source or input... In fact, if you go to the front of the unit - that's a Sanyo right - find the grouping of buttons that change the channel, volume etc.. There should be a button marked source or input there.. Press it as many times as it takes to get back to the input source your cable is on...
If you have any problems let me know...
Bill
Nov 24, 2007 | Televison & Video
SanyoDS25390 Tv good picture buzzing noise
What are you using as a source? If its a cable/satallite box, double check that first. If its a video input or a scart input, swap out the cables. If it still there you could have an input problem or a filter capacitor going bad. Does the hum get louder with sound? If it does it is an input source and or cables. Good luck Ps please dont forget to rate this thread.
Nov 25, 2006 | Sanyo DS25390 TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
