They build up and allow us to make 3 cups then it says to clean brew unit
On the left side of the brew unit there should be a metal wire that is bent in the shape of a U that scrapes the grounds off the top of the brewing chamber - the puck then should slide down a small chute that is the shape of a W - into the waste container. Sometimes the Chute can be found installed upside down - shape of an M - it is easily reversed if that is the case
SOURCE: Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
SOURCE: grinding and dumping coffee without making a cup.
Check the grind it might be too fine, then check the screen under the red o-ring in the brew unit it might be blocked.
SOURCE: when I brew a cup of coffee there are coffee
Take your K-cup out and it splits into two pieces. The buttom half has a chamber where coffee grounds that slip out can sit. When it builds up you tend to see allot of grounds in your coffee.
Also check that your top needle seat is there and in good condition.
If you need assistance further my email is [email protected] and my site which sells keurig parts is http://wwww.Igotsweetdeals.com/
Hope I helped you!
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
SOURCE: brewed coffee goong into used grounds holder
HI
That is a stripped thumbscrew. You need a new one. When it starts to brew, the stripped thumbscrew pushes up and allows the coffee to fill the head and dredge drawer.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Testimonial: "nailed it! Now I just need a new thumbscrew"
