SOURCE: admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
SOURCE: no fill - drain pump running - I assume stuck float switch
remove the bottom plate of the dishwasher and the bottom pan is revealed. reason the drain pump is running will be that this pan has water in it ie you have a leak. mop out the water and dishwasher will work - switch off mains when you do this
SOURCE: hotpoint aquarius wf325 filter problem, not accessable??
If you are certain that your washer has no filter at the front behind the lower removable panel, it is usually held on by 3 scews which you have to undo, or just held in place with plastic lugs, then you will have to remove the lower rear cover of washer. Locate large black hose at lower right of tub, remove clip and hose.
inside you will see the plastic filter,
Remove and clean filter, refit filter and plastic ball if it has one, refit hose and clip securely, and water test for leaks.
Be careful when you remove hose as there will be water run out.
Please make sure you have it unplugged before you do all this.
Plz rate my solution, and feel free to leave any comments.
Thanks.
SOURCE: our amana nfw7200tw front load washer won't drain.
You can access through back panel. But before you do, make sure there is not a kink in the drain hose, it is very common
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
