SOURCE: 2002 2500 Silverado tailgate handle will not release catches
You will need to remove the trim piece the is under the release handle. Be carefull those things tend to break the little tabs that hold them on. Anyway pop (pry) it off with a screwdriver. Once it is off you can see that the little clips that hold the rods to the handle assy are broke. These clips are color coded. Most likely yellow or green. You might be able to get them at say Pep Boys or some place like that but they might make you buy an assortment package , then you get clips you will never use. Good luck, hope this is helpfull.
SOURCE: extended cab door won't open on 2000 Silverado
Take the door panel off and reset the rod on the bottom latch
SOURCE: Aqualtis washing machine door locked, need quick release?
yes there is a quick release
the door lock have 3 wires u should connect 2 of them together the first one and the third
but its dangerous if there is kids cause u will b able to open the door while its on
SOURCE: bissell 3595 handle release pedal spring(?) missing
I just fixed this on my Bissell PowerForce model #6594 vacuum myself. Woo Hoo for me. :-)
I called the local vacuum repair guy and he told me he'd repair it for me if I insisted but that since my machine only cost about $80 (a lot of money for me) it would not be worth the $40-$50 repair. I should just buy a new vacuum (from him I assume).
My machine works great so I sat down on the floor and after removing 5 screws and a little tinkering I got my machine apart. I had to take the brush and belt area off and then the upright part came off the base. Make sure you unplug your unit before working on it.
Next I could see where the Handle Release Pedal (HRP) on the bottom of the unit had been cracked. It's a molded piece that has a slight curve in it that allows it to spring back into position to hold the vacuum in the upright position or to keep the vacuum from going totally flat.
How it was installed I don't think they meant for it to be easily replaced but after using a screw driver on one side and a letter opener on the skinnier side I pried the molded houseing out from around the HRP just enough to let the it release. I did need a third hand for that part.
