Washing Machines Logo
B
Bruce Story Posted on Nov 13, 2018
Fabric softener doesn't dispense.Bosch 500 nexxt
  • JP bkrmain Nov 13, 2018
    It’s possible the line which drains it into the washer. We had this on our Maytag stack set. Took off front of machine & cleaned the hose. Amaging how goofy it became! Very thick stuff. We Quit using softer as if it thickens in the line it might be ruining other parts. Ck your manual to see were the line is & if assessable by removing a side or front panel, etc good luck
JP bkrmain
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Nov 13, 2018
JP bkrmain
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
3217
Points
7
It’s possible the line which drains it into the washer. We had this on our Maytag stack set. Took off front of machine & cleaned the hose. Amaging how goofy it became! Very thick stuff. We Quit using softer as if it thickens in the line it might be ruining other parts. Ck you manual to see were the line is & if assessable by removing a side or front panel, etc good luck
2 Related Answers
Anonymous
  • 121 Answers
  • Posted on Sep 14, 2009
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Anonymous
  • 500 Answers
  • Posted on Aug 17, 2011
SOURCE: Fabric softener does not get
Hi emily446,
Take out your Tray from the drawer (Usually un-clips on the sides or top)
Then clean the holes inside the drawer at the roof. There will be small holes, clean these with either ear-buds or toothpicks. These holes get clogged quite often, and cleaning them will allow water through to the machine again.
Also clean the tray, especially near the hole at the back where the fabric softener gets siphoned through.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
1helpful
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Fabric softener does not get dispensed into wash on my Bosch Nexxt 500.
Hi emily446,
Kind Regards
JEDEMEYER1
Fabric dispenser still full after washing completed
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
6helpful
2answers
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
4helpful
2answers
Bosch nexxt washer fabric softener not draining
2helpful
Fabric Softener Dispenser wont drain
Try using a long handled babies bottle brush to clean out the rear of the dispenser and the tube leading down into the drum
1helpful
Bosch Nexxt series washer - water in softener dispenser
Hi. Remove dispenser, and thouroughly clean.
This should solve problem. If problem persists, don't worry about it tomuch, as long as it takes the conditioner down that is the main thing.
5helpful
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
