Specifically looking for info on the adjustment turrets
SOURCE: Bought leupold rx 2 rangefinderclearance no manual
I need a manual for a leupold RXII range finder.
SOURCE: Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
SOURCE: i have a weaver k-8 scope with adj. rings on front bezel ??????
the front ring is for adjusting point of impact at a given range,,,its called a "parallax ajustment" it corrects for the scopes inaccuracies over its full range say from 10 yds to 100 yds there a bit of a pain on a hunting rifle as you need to focus them every time and that slows down your shooting, when only a snap shot will get the kill you cant wate to mess about focusing the darm scope so i never use them on my rifles,,unless im target shooing,, or im snipping when i have time to take my shot,,,
(a head shot only!) only a parallax scope is spot on aim from 10yds to infinity
Testimonial: "waiting for your response on the weaver k8"
SOURCE: I have a 25 year old Redfield 6X18 scope, with an
bullet drop compensation,,,,compleat hog wash!
no such thing in a scope, only a realy pricy one like £1500.00p worth and there not that good! but there coming soon! driven by a lazer for range finding,,,
still your scope has clouded up becouse its leaking
water has got into it, it could be repaired but its not cheap to do, it needs a complet strip down all the class cleand and new seals then a re-gas and it should be as good as new for another 25 years or so,
any good scope with mill dot will work for you, you just need to relurn the bullet drop over again,,and with the years of shooting you have had that should come easy as falling over,,,why not just get a good prised 3/9x40 mill dot and try that out insted, you will be plesently pleased with todays mid priced range scopes treet your self, and save money at the same time
Testimonial: "Both Leupold & Nikon DO have bullet drop compensation reticles, which are similar in principal to the mil-dot. The BDC scopes are becoming very popul"
SOURCE: new leupold scope
You may need to purchase a base with a built in taper to help zero your scope. Look for "20 MOA scope base" if interested in purchasing. Go Here:
http://www.thehighroad.org/showthread.php?t=230774
for a discussion and info that may help.
