Welding Tools Logo
sarumi olamilekan Posted on Nov 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My name is olalekan am a technician with nigerdock FZE NIGERIA.i want to how to correct help 21 from dynasty 350 welding machine.
domberg2008
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on Jan 01, 2019
domberg2008
Expert
Level 2:
New Friend:
Answers
56
Questions
0
Helped
26809
Points
136
Help 21 Display
Indicates voltage or current feedback has
been detected with contactor off. Contact a
Factory Authorized Service Agent if this
display is shown.
Not the best news but i would say call Miller and see what they tell you to do.
1 Related Answer
Anonymous
  • 87 Answers
  • Posted on Oct 20, 2009
SOURCE: Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Testimonial: "appreciate the help."
Miller Dynasty 400. Welding aluminum at 220 amps cutting heels cutting out, saying "weld cables - see owner manual". Why is that, I have a heavy enough torch and it is water cooled?
Question edited for clarity.
Try straightening out the cables. Also, Clean and tighten all weld connections (see Section 9-1). Check for and remove anything blocking fan.
Dynasty 400 Maxstar 400
Miller Welding https://www.millerwelds.com > owners-manuals
Jan 16, 2017 - An error relate to the weld cables has been sensed. Straighten out or shorten weld cables. [SEE] [O.M.] See Owner's Manual: See. Section 9-4.
68 pages
Help 10 code on miller dynasty 300 welder
https://forum.millerwelds.com/forum/welding-discussions/6001-dynasty-dx-%7Bhel%7D-%7Bp10
What settings are best on a miller 350 dynasty for
Use the best argon gas, ac polarity, continous frequency, tungstene must round and not sharp, rather use the zirconiated than the thoriated and make sure you got the size or diameter of tungstene according to your welding amps
1helpful
Dynasty 350 tig welding machin
When the display shows RMT it means that the torch trigger is depressed. If that is not the case then the trigger might be bad or shorted.
http://www.millerwelds.com/om/o245729c_mil.pdf
I am getting holes appearing when I stop welding. There is nothing wrong with the gas (pressure/post/preflow checked) as i have checked it all out. I have put a new torch on and a new regulator but it has...
Wow what a great machine. You have so many options that you should be able to control the ending arc. Yes, you should be able to adjust the intensity of the HF. Also if you use the Sequencer Control, you should be able to finish the weld in a slope manner. I am including the owners manual. Operation starts on page 38. Miller has a team of welding engineer that will be able to help you set up your machine. Wish I had one.
2answers
Help code 11 on the board keeps popping up its a 350 syncrowave lx
According to my technical manual a help 11 code indicates that the output selector is not in the correct position. What this means is that say you have your aluminum piece all ready to be welded, you lean over and make a little adjustment to your balance and this code pops up, its because your output selector switch (the big handled 3 position rotary switch on the fron of the machine) is in the wrong position. Either DCEN or DCEP when you in fact need AC.
I see this all the time on the dynasty 200's we have in the lab when people are set for DC straight current welding and try to adjust AC parameters. Such as balance and frequency.
Throwing this code does NOT mean there is anything wrong with the machine and I would not recommend bringing it somewhere for someone to look at. Just double check your settings and that should be it.
-Ross
ps, you might want to just go ahead and grab that handle and see if you can feel the knives on the inside of that switch engaging. Also make sure it is not off one way or another and is engaged fully.
2helpful
I have a help 12 code on my little dynasty machine, and no manual to tell me what it means, is this a major problem with my machine
On this page enter your serial number and you will be able to download your manual http://www.millerwelds.com/service/ownersmanuals.php In the Dynasty 350 manual I see no "Help 12", there is a 32 and 22. If the Help 12 is only displayed when you push a button, it is saying the combination you have selected is not valid.
2answers
Fan is always running wether welding or not.
Have you turned it off and try blowing compressed air on the cooling fins?
Top Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Welding Tool Expert? Answer questions, earn points and help others
