Refrigerators Logo
Steven Covert Posted on Nov 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire FFHS2611LB4 here. Freezer set to max, ice cream not solid, on edge. Replaced thermostat and all power is cycling off and on every few minutes!?
Bought a kit fan motor/defrost wire/thermostat. Opened it up and found a large ice block at the top of the radiator, the radiator itself was clean and clear. Measured 30 ohms on heater and fan was spinning fine. Replaced the thermostat by splicing in new one. Used one of those red inline crimp on with the blades, instead of the included connectors they were too big. I'm an electrical engineer, have the parts. Wrapped up good with black tape. Started it up, went fine. Got up in the morning, freezer was cooling OK, but opened door and there was NO light - no power anywhere! Then I heard a beep and the lights came on, display lit up with the set points. Then all power off again a few minutes later. No power anywhere, even light in ice/water dispenser dead. Seems all power going on and off. Was fine before. All I did was use a hair dryer to melt the ice block at the top of the radiator enough to pull it out to replace the thermostat. Could the thermostat be getting moisture and shorting? Connectors were wrapped tight. Of is it cycling all power because the pump is getting hot? Ideas? Thanks in advance!!
Chris Huff
Level 3:
Top Expert:
  • Frigidaire Master 6,289 Answers
  • Posted on Nov 13, 2018
Chris Huff
Frigidaire Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019995
Points
74913
Evaporator coils should have uniform frost pattern over whole coil. If there is a block of ice only at top, your unit most likely has a freon leak and is low on freon. If whole evaporator coil is a block of ice, then it’s a defrost problem.
5 Related Answers
Anonymous
  • 72 Answers
  • Posted on Jul 11, 2007
SOURCE: Hotpoint FZA50 Freezer not cold enough
try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Anonymous
  • 1239 Answers
  • Posted on Oct 10, 2008
SOURCE: After cleaning coils and in back of fridge, it appears that the defrost keeps cycling every 5 minutes
hi
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Anonymous
  • 700 Answers
  • Posted on Dec 26, 2008
SOURCE: refrigerator/freezer not cooling evenly top to bottom
good then go ahead and ohm out the sensor and the relays to see if the resistance is close to the normat. 70 degrees is roughly 1000 ohms. relay you are lookling for continuity or open. then you can also ohm the fan motor too. let me know what you find;.that will determin whts bad and whats good
Anonymous
  • Posted on Apr 21, 2009
SOURCE: Error Code ER FF
I had the same problem. I can tell you that simply unplugging the fridge and letting it defrost isn't going to work. You need to get take it apart.
I had the Er FF code about 2 months ago and let the freezer defrost for a couple hours and it started working again. Then two days ago I got the error again. This time I decided to get inside there.
First and foremost, UNPLUG the fridge and TURN OFF the water!
Next empty everything out of the freezer and start taking it apart. You have to get everything out of it to get that back panel off. This includes the ice maker and the rails that the drawers slide on.
Now that the freezer is completely empty there are two screws that hole the back panel on. In my freezer one is a white screw high in the center and one was a gold screw in the little panel that the ice maker hooked up to.
Next grab the back panel by the little fins on the top of it in the middle. Give it a good firm pull, but take care not to yank it too far... it's still connected by wires back there. When I pulled my panel out I found a HUGE chunk of ice on the top of the panel just to the right of the fan that feeds cold are to the fridge. Get that thing off of there taking care not to damage the foam insulation and watch those shiny metal fins that are behind the panel.
While you're putting it back together try to dry everything off as much as possible (I tried see the bright side of the whole evolution and realized I could really clean my freezer).
Once it's all put back together plug that baby in, turn on the water, and enjoy the next four hours as it gets back to being cold.
I'd say you need moderate tinkering skill to do this. If you only own one screwdriver and you never use it you should probably call someone.
Hope this helps!
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Jul 13, 2009
SOURCE: Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
3 year old Frigidaire upright turning ice cream to soup. Meat OK for now. Can't find the manual (of course) or locate the thermostat. Where is the thermostat? other ideas?
the fridge section will not freeze ice cream as the lowest setting 1- is not cold enough
The thermostat is normally on the side panel inside the compartment and is measured 1-10 with 4 being around the best setting
if you are referring to a 2 door fridge where the top or bottom section is the freezer, that temp will be preset in the factory and has nothing to do with the thermostat but indicates - door not sealed properly
compressor failure and needs a technician to check out the reason why
1helpful
Why won't my Fridge/freezer, freeze ice cream? But freezes popsicles and meat, model number MTB2195AE* Im GUESSING its the defrost control that needs to be replaced? NO ICE build up.
Your have a good idea re the defrost timer. But there is also a thermostat that turns the compressor back on when the temp hits a certain point during the defrost cycle and defeat the normal cycle.. Check that out.
Ice cream is not freezing on FFUS2613L Frigidaire Refrigerator
Thanks for your post, friend!
I understand that your ice cream inside of your Frigidaire refrigerator, FFUS2613L. I would turn down your thermostat to see if that would help correct the issue of your ice cream not freezing. I hope this helps. -Matt
1helpful
My icemaker is making hollow ice cubes what is causing this?
I would guess that the freezer is turned down too low to give the water in the ice maker time enough to freeze solid before the action of the ice maker completes it's cycle. Turn the freezer thermostat up to max and see if this makes a difference. After checking, if the ice is frozen solid, then dial it back half way between where you had it set and max, then check again.
Runs all the time set on lowest setting but ice cream is soft
if you put it on highest setting will the ice cream but hard?
if you did and still soft it could be one of these problems:
system needs recharge
compressor short cycle
thermostat defective
well a tech will do the diagnostics but it will prob. be $80
is it worth it?
thats not even parts and labor...
hope this was alittle helpful
to check this one you need refrigeration tools
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Freezer side will not keep ice cream, popsicles or orange juice frozen. it will make ice in ice cube trays-the ice maker makes very few ice cubes.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check
, defrost heater, defrost thermostat.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Freezer not cold enough/ice maker not working
Check the coils in the freezer to see if they are blocked with ice.
Ice cream going soft
What is happening is that ice cream has a lower freezing point that water. Perhaps 5-10 degrees for ice cream. Now, the problem with the freezer is 1 of 3 things. 1. Make sure the air vent coming into the freezer is not blocked. 2. Check the thermostat setting and make sure it is on the coldest setting. You can always bring it back up when you get it colder. The thermostat may be going bad. 3. The freezer may be going bad (compressor or other componnets). If it is older than 12-15 years, then you may be better served getting a new one. This may mark the beginning of the end. Check these and let me know how you do.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
