Computers & Internet Logo
M
MANZOOR AHMAD Posted on Nov 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE PURCHASED A USED VIEWSONIC VG2428WM-LED. IT CONTAINS TWO USB PORTS AT BACK SIDE. CAN I PLAY VIDEOS DIRECTLY FROM MY USB. OR IT IS ANOTHER TYPE OF CONNECTION. THEN WHAT IS USE AND HOW I USE IT?
  • Larry Ng
    Larry Ng Dec 18, 2018
    Hi MANZOOR AHMAD, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    you will not get those USB port to display video
    they are just for expanding your existing PC hub.
    for example plug in a mouse to the monitors USB port, extended by the PC to the screen. see?
    no PC stated, not one word about the 2 thing on your desk, A PC connects to this monitor on the VGA or DVI ports, called video ports.
    can I play videos?, well not with just 1 monitor you never said what the videos are located, on DVD, or on the INTERNET or local servers or what>? no VIDEO sources stated.
    the VGA or DVI will plug into most PCs.
    some newer PCs are only HDMI or DP ports.
    but no PC stated so can't help you.
    the VGA port is optional +Dsub, D shell sub miniature.(15 pins)
    your manual states this>
    "D-Sub cable (available in some countries only)"
    your country not told or photos of the rear of you monitor posted, so we can see it.
Larry Ng
Level 3:
Top Expert:
  • ViewSonic Master 14,585 Answers
  • Posted on Dec 20, 2018
Larry Ng
ViewSonic Master
Level 3:
Top Expert:
Answers
14585
Questions
0
Helped
3277378
Points
66542
"PLAY VIDEOS" Please tell the helper what that means? tell where the videos are at? I can name 1000000 places, or devices. using PC? or what. tell us what plays said video's
if PC tell what model first.
and USB does not do video in that monitor.
Michael McGarghan Jr
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Nov 13, 2018
Contributor
Level 1:
New Friend:
Answers
6
Questions
Helped
1773
Points
12
Your model is listed here on the Viewsonic webpage:
https://www.viewsonic.com/us/vg2428wm-led.html
The connections on the monitor, appear to be:
Connector
(2) USB 2.0 TYPE A (your accessories will use this for additional USB ports, extending your available ports from the use of a USB A - to - USB B in the back of the monitor. (Many people will recognize this cable used for connection of a printer to the main computer.
(1) USB 2.0 TYPE B [assuming the above description wasn't answering, the USB B port looks close to a square socket, and is an input from the main USB port or hub, and the (2) USB A ports are outputs from the computer or USB hub.
(1) 3.5MM AUDIO IN [this is used to plug in headphones most commonly].
(1) VGA (royal blue DB15 connector video, no audio)
(1) DVI-D (white connector for Digital Video cable audio & video transmit on this connector, precurser to HDMI.)
Unless this USB B cable is connected to a host computer (most times, that is what its used for), it will not allow the 2 USB ports to work as designed.
Steven Stevenson
Level 1:
Habit-Forming:
New Friend:
  • Contributor 28 Answers
Steven Stevenson
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
28
Questions
0
Helped
7185
Points
79
You can. " The 2-port USB hub gives... convenient USB device connectivity", according to the manufacturer's Product Data Page here: https://www.viewsonic.com/us/catalog/product_datasheet/view/key/vg2428wm-led.html
The USB hubs will allow you to play output from devices of your choice directly to the monitor. Not for your computer, since this will already be connected to your computer by some other type of cable (probably HDMI).
I tried to find an English manual for your device but for some strange reason it's not readily available, even on the Viewsonic product page:
You could try a more thorough search with your favorite search engine). If you can't find the manual, contact Viewsonic directly and ask them where you can find one. Afaik they're a budget manufacturer, so they may or may not come up with one.
To use the USB inputs, you'd need to know how to select between monitor inputs, the manual will tell you this. Personally I wouldn't be bothering with it unless there's a pressing need... USB inputs are something you might use on a TV, but will I think have little need for on a computer monitor, where probably everything you want to play is on your computer anyway and playable on the monitor with better quality and more options without smegging with USB connections.
If it's a new monitor, you may want to test the feature once for each USB port, so you know everything works as it should.
Brett Duxbury
Level 3:
  • ViewSonic Master 4,352 Answers
Brett Duxbury
ViewSonic Master
Level 3:
Answers
4352
Questions
0
Helped
1120032
Points
13423
  • Brett Duxbury
    Brett Duxbury Nov 13, 2018
    i found a user manual but it doesn't explain the usb up and usb down ports and how they are used ?
  • Larry Ng
    Larry Ng Dec 26, 2018
    Brett.
    it is just a hub (it has no relationship to the video at all. its inside the monitor but is electrically separate.
    some PC laptops super old and super cheap
    had only one USB port, or just 2,
    so then you want to add say web cam or usb phone
    or other 10,000 USB devices, then what.?
    well the maker added USB hub, to end the bad day. Viewsonic did that this.
    it is ONLY for adding more USB ports.
    that is all it does,
    the wiki covers this, read this please'
    2011 model
    the Hub can reduce clutter,
    means one cable from PC to monitor
    then monitor lets other USB thing fit there
    when cables hidden behind it, (cuteness factors)
    https://en.wikipedia.org/wiki/USB_hub
5 Related Answers
wings_it
wings_it
  • 141 Answers
  • Posted on Dec 20, 2008
SOURCE: connecting computer to tv using usb ports
Have a look at : http://www.svideo.com/compaq1700.html
cheers
florin_decad
Daniel Florin
  • 203 Answers
  • Posted on Mar 06, 2009
SOURCE: How do i connect a tv to a compaq presario r3000 for ex video out
yo can use wich one you want, eiter VGA or Svideo ,for VGA you must have a special cable, if your tv is a lcd is ok you dont ned special conector just plug in normal cable betwin you laptop and the tv. to have sound on tv you need to get the sound from headset on you laptop. your video driver has to be the latest driver, from video driver property you can change the video on tv to use them at the same time.2 screen has to be set on lower rezolution to work at the same time.
Anonymous
  • 112 Answers
  • Posted on Jul 08, 2009
SOURCE: Can the modem's ethernet port connect to a video game console?
Most modems that have both usb & ethernet connectors are either/or, not both. I recommend using
the ethernet connection to your computer than the usb - the ethernet connection is faster & more
reliable. It also frees up your usb port for other use. If you want both your computer & game console on
the internet, then you need to buy a router which will allow you to share the modem.
Anonymous
  • Posted on Jan 09, 2010
SOURCE: wacom intuos3 led lights up for a second when
try wiggling the cable at the tablet end.
I had the same problem, seems like the contacts from the cable to the tablet aren't that solid.
After a few wiggles I got contact again (pc made sound : a new usb device was detected), I just taped the cable so it wouldn't move again.
Anonymous
  • Posted on Mar 05, 2010
SOURCE: My DVD player has a USB Port.. But while inserting
i have a dvd recorder lg DR 275 with out USB port !!!! i want to fix for it a usb port how can i do that
How to access the usb input from the tv screen?
  • To play USB media, you must first save your music or images onto a USB thumb drive.
  • Remember: The USB thumb drive must be formatted as FAT32.
  • Files on the USB thumb drive must end in a supported le extension (.mp3, .jpg, etc).
    • The player is not designed to play media from external hard drives or mp3 players.
To play your USB media:
  1. Connect your USB thumb drive to the USB port on the side of theTV.
  2. Highlight the Media app and press OK.The Media App launches.
  3. Highlight your USB device in the list and press OK.
  4. Highlight the type of media you wish to display: Music, Video or Photo. This info can be found in the manual here: http://cdn.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
1helpful
I want to connect a Canon G11 camera to the USB port on a LG LED LCD TV 37LES300 television. What should the tv settings be??
You cannot do directly to the USB port since the TV cannot communicate directly to the camera.
You need converter to convert USB to composite video and use the composite video input ont he TV.
You can learn more here:
http://www.ehow.com/how_6611359_connect-webcam-tv.html
I purchased a U-VIDEO USB video camera (The Sharper Image) and took it on vacation. I am attempting to upload the videos. Step 1 is Select Video, plug camera into USB port, Open the YouTube Video...
Keep it simple- download vlc player which plays EVERYTHING. Plug in your camera to usb - start player - direct to usb device and play back.
That file you are looking for should be in your programs directory.
My RCA L46FHD37 with a Usb port won't play the
The RCA L46FHD37 can only play MP3 audio files and display JPEG image files from a USB drive. See page 41 of the manual to see the details on using a USB flash drive with this TV. I found the manual here: http://www.hdtvsolutions.com/pdf/L46FHD37_0.pdf .
You will need to connect some type of computer with a video player to watch videos. Media streaming boxes, the Stick Computers (like the Intel Compute stick), some tablets/phones and most laptops would be able to connect to the L46FHD37 and display your video files. Some DVD and Blue-ray players will also be able to display these videos, depending on the format and codecs.
I wish that I had better news for you.
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
1helpful
.mkv doesnt play on LED:UA32C5000 but plays on LCD:LA32C530
Hi
I am also facing similar problem with recently purchased LED 46" P6200. Do not know the reason? Does anyone has any idea why it is so? Thanks
2helpful
5answers
White screen.
If you are using a usb hub, connect the lifecam directly to one of the usb ports on your computer.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
