Exercise & Fitness Logo
Randy Stine Posted on Nov 13, 2018
How do we replace the speed sensor cables. Where do we start to replace the original cables?
On our Spirit XE295 elliptical the RPM's quit registering. Only readout working correctly is timing. Spirit sent us (2) XE295-034 250m/m-Sensors W/cable.
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 17, 2008
SOURCE: nissan ga15 engine idle adjustment locations
The idle speed is computer controled, it is not adjustable, you most likely have sludge in the throttle valve and the idle speed control air bypass valve, clean them with carb spray with the engine running.
Anonymous
  • 3 Answers
  • Posted on Apr 09, 2009
SOURCE: Speedometer sensor/cable needs replacing
try looking at the book theres a cable from the transmit ion to the speedometer and it could be a bad connection or theres a gear in you're trans that spins and tells how fast you're going sometime those go out haven't had that problem yet but i built my truck from the ground up
Jonah Oneal
  • 14092 Answers
  • Posted on Aug 05, 2009
SOURCE: o2 sensors and knock sensor keep triggering check
IF YOU REPLACE SENSORS YOU HAVE TO ERASE PCM CODE TO TURN OFF CHECK ENGINE LIGHT.IF YOU DONT IT WILL KEEP LIGHTING UP.
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Oct 13, 2009
SOURCE: The location of the speed sensor. How can I get to it?
1995 Jeep Grand Cherokee 4WD 5.2L MFI 8cyl
The Vehicle Speed Sensor is located in the Transmission / Transfer case.
For more details, can visit the Jeep ZJ Service and Repair Manual.
Good luck. (remember rated this help)
Anonymous
  • Posted on Jan 08, 2011
SOURCE: Schwinn 431 Elliptical doesn't register rpm's, distance, etc.
I have this same problem and called the customer service. The problem is that the rpm sensor is not working. It could be the sensor or something else. They had me check the connections first for the wiring harness at the top and middle and then sent me parts to work on the inside where I have my problem. I am still working on mine because the magnet was installed on the wrong side of the flywheel. Hope you don't have this issue.
1 have a spirit treadmill machine model ct800 since last day the machine is shown Low Speed error. Please suggest me what to do
LS Computer doesn't read the single 8 seconds from the speed sensor The gap between speed sensor & magnet is too far. Adjust it to be within 5mm.
Clean and vacuum inside unit and around senor, check connector is solid and no fray or rubbing on wires.
If the sensor is damaged and caused short circuit. Replace a new speed sensor cable.
Error messages ellipticals
Precor Error Code 22 Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Could po320 be drive shaft speed sensor
code p 0320 refers to crankshaft position (CKP) sensor /engine speed (RPM) sensor---circuit malfunction====causes --wiring--CKP/RPM sensor ---ECM check the wiring to the crank position sensor
replace the crankshaft position sensor
Where and how often do I lubricate Spirit XE295 Elliptical
The manual for this Elliptical doesn't show any lubrication needed.
Is the unit starting to make abnormal noises like squeaks, thumps, or extra/less resistance?
This is from the owners manual for the Spirit XE295.
Maintenance:
1. Wipe down all areas in the sweat path with a damp cloth after each workout.
2. If a squeak, thump, clicking or rough feeling develops the main cause is most likely one of two
reasons:
i. The hardware was not sufficiently tightened during assembly. All bolts that were
installed during assembly need to be tightened as much as possible. It may be
necessary to use a larger wrench than the one provided if you cannot tighten the
bolts sufficiently. I cannot stress this point enough; 90% of calls to the service
department for noise issues can be traced to loose hardware or the rear rails being
dirty.
ii. Dirt build-up on the rear rails and polyurethane wheels are also a source of noise.
Noise from build-up on the rails can cause a thumping sound that you would swear
is coming from inside the main body of the machine because noise travels, and is
amplified, in the tubing of the frame. Clean the rails and wheels with a lint free cloth
and rubbing alcohol. Stubborn build-up can be removed with your thumbnail or a
non-metallic scraper, like the back edge of a plastic knife. After cleaning, apply a
small amount of lubricant on the rails with your fingers or a lint free cloth. You only
need a thin coat of lubrication, wipe off any excess.
3. If squeaks or other noises persist, check that the unit is properly leveled. There are 4 leveling
pads on the bottom of the rear rails, use a 14mm wrench (or adjustable wrench) to adjust the
levelers.
My precor keeps saying start pedaling
The most common cause for the Timer to Stop After 7 Seconds on a Precor Elliptical is NO RPM Feedback.
Knowing the status of the unit from its last use as well as the last service or part replacement is a great place to start.
Check the connection of the speed sensor to the lower board. Reset connection if necessary.
Check the magnet. The magnet is located on the user's right crank arm on versions 1 and 2 and the user's left on version 3. The magnet passes the speed sensor with each revolution of the crank arm. The magnet should be installed so that its south pole is facing the speed sensor. You can check the magnet polarity with another magnet that has marked poles or a compass. The north pole of the marked magnet or the south facing needle should be attracted to the magnet. Correct magnet installtion if necessary.
You may also check the spacing of the speed sensor to the magnet. The spacing should be 1/8" to 1/4". Adjust if necessary.
My Precor Elliptical Shuts Down After 7 Seconds what is wrong
Efx time out after 7 sec
My Precor Elliptical EFX 546 Timer Stops After 7 Seconds, what is wrong? The most common cause for the Timer to Stop After 7 Seconds on a Precor Elliptical is NO RPM Feedback.
My precor efx 544 has stopped recognising that i am using it. does not display strides or calories burned. any ideas?
Also see the following link for additional information.
Replaced Crank Arm on Precor EFX 546 and Display Doesn Work
My Schwinn 431 Elliptical rpm sensor is not working. I talked to customer service and they sen me new parts and pictures. I'd call them today but they only work M-F. anyway, it looks like the flywheel...
I took a magnet from a magnetix toy and secured it to the correct side of the flywheel. It's working now...I just finshed doing it. Hopefully it'll continue working. Thanks for pointing out the magnet was on the wrong side.
Battery has been replaced but the keypad only lights up for a second when you start pedaling....it then continues to flash on and off....no error code given
2helpful
Top Spirit Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
