SOURCE: older amana electric dryer model #le8457w, wont heat up
You probably have a bad heating element. This is just about the easiest dryer to repair ever. Take the screws off the base and pull the front off. The heater is on the left on bottom and has all the fuses mounted on it. 2 screws hold the whole thing on. get it out and give it a look over for a bad coil. Not sure if it is bad? Take it to the appliance parts store and let them guys confirm if it has a problem. they will be glad to do so because they hate to have to give refunds on electrical stuff and they know the cust will get bent outta shape. Trust me. How do I know? Because my friend I used to own and operate an appliance parts store.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: clicking/tapping noise back of dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgj
SOURCE: have an older model amana elec dryer, amana no
Here
It will help
Dryer
Repair Squeaks,
heatman101
Asker's
Testimonial "That answer was very informative - thank you for
taking the time to educate me. " - teresa241964
SOURCE: TV won't turn on. I hear a clicking noise near the power supply. I have no picture or sound
This is usually and most likely caused by the power inverter/board. There are capacitors and other components that can burn out and will cause the power not to be transfered correctly
Here
It will help
Dryer
Repair Squeaks,
heatman101
Asker's
