SOURCE: The System shuts off automatically
System detects power rail irragularities.E.g +5ve the fault is in power supply section.
SOURCE: instructions on how to program the Intermatic EJ351C
take a look at this :
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
-or -
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
hope this helps
SOURCE: Power outage this am. Wii won't even turn on
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
SOURCE: Our radio automatically turns on at midnight. I
Your radio must have an alarm switch that will allow you to choose between radio and buzz. I'm sure you
will find it. Just take a good look.
SOURCE: Looking for the instruction manual for Leviton timer model 6651-I
6651 manual online here: http://www.smarthome-products.com/productspecs/DI-000-06651-22C.pdf
