The other components (CD, etc.) are working well. There have been instances in the past when the same message appeared, but the Internet was not working. However now the Internet is working well throughout the house. Any help would be greatly appreciated.
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
SOURCE: Internet connection via wireless router
change the settings in explorer ... Tools- Internet Oprions- Connections
SOURCE: my wireless router is not transmitting a signal
If the router is not transmitting signal the best thing to do here to correct the problem is to reset and and reconfigure the router, to reset it press and hold the reset button of the router for 10 seconds while power is ON and then after that power it OFF for 10 seconds and reconfigure it back.......
SOURCE: Hi...my wireless internet was working fine.....the
Open up a command prompt
Start --> Run --> CMD
then type :
ipconfig /release
then type:
ipconfig /renew
That should give you a new IP address.
