Not really unless you were to run an ethernet cable from your existing network to a location outside of the current wi fi range.
A repeater would be better
https://www.tomsguide.com/us/best-wifi-extenders,review-2225.html
It hears the wi fi signal so you put within the signal range near where the signal still can be heard near the extent of the current wi fi range. It will hear the signal and then re-transmit it to extend the signal range .
You might be able to use a gain antenna of 5dbi 2dbi is lost in the cable usually so it is 3dbi which is twice the level
http://computers.mwave.com.au/electronics/High-Gain-Antenna
another method would be a omni directional antenna facing the coverage range . But it is beaming in one direction .
which means more signal strength in one direction
https://www.mwave.com.au/product/draytek-ant1207-highgain-omnidirectional-indoor-antenna-black-ac04622
SOURCE: How can I increase my
Try moving the wireless router around and or higher.
If the wireless router is in a different room and the room has concrete walls of foils insulation in the walls, this will weaken the wireless signal. AND/OR
You can connect add a antenna to your computer. Have a look at this device.
Normal
0
USB High Gain Antennas
www.pricewatch.com/gallery/networking/high_gain_antenna
SOURCE: Any suggestions for to using
All you need to do is turn off the DHCP on the WRT610n
All you need for the ADSL modem is your login information to your provider
Take it back to where you got it, if it's new.
Otherwise it could be the Wall Wart/Power Supply or something internal.
I suppose it could also be a bad setting or flash. Try a Hard Reset. Usually holding the Reset Switch for 10+ Seconds Resets everything to factory
