SOURCE: flashing EFO error code
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
SOURCE: Beeps, then error blinking in display 'EFO'
The error codes are not shown in the owner's manual. They would be in the technical information for the washer. They are intended for service technicians. The chart of the error codes is shown below. The EF0 is a group code that indicates that one of the faults associated with error codes beginning with "EF" occurred. This group includes EF1, EF2 and EF5 as shown in the chart below. To determine the exact code of the failure, you can use the procedure in the second image to recall the specific code.
If the washer had excessive suds, you can likely drain it after the suds dissipate. Make sure that you are using HE (High Efficiency) detergent in appropriate quantities in the washer.
If the EF5 error occurred, you could have the hot and cold water lines switched on the back of the washer. You could also have a problem with the temperature sensor.
If the EF1 occurred, you likely have a drain problem. Check the drain line for kinks or clogs. To access the drain pump in the washer, you would need to unplug the washer and remove the bottom front service panel. If you access this area, you can check the pump. Be careful. If the washer tub is still full of water, it will drain out through the pump if your pull off any of the hoses to the pump. You can evacuate most of the water from the tub by using a wet/dry shop vacuum. A clog in the pump could be causing a drain problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: HI, The machine displays "EFO"... We
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
SOURCE: EFO, E10 error Message
E10/EFO error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
