Heating & Cooling Logo
C
Casaundra Mckenna Posted on Nov 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I locate model number on temco pre-vent wall heater. I cannot figure out how to light the pi,or on heater. Just moved into my new place today and its freezing. Please help
Paul Carew
Level 3:
  • Heating & Co... Master 3,807 Answers
  • Posted on Nov 12, 2018
Paul Carew
Level 3:
Answers
3807
Questions
Helped
1298638
Points
10523
Inside the case or under the bottom on a plate that slides out
5 Related Answers
Anonymous
  • Posted on Feb 13, 2009
SOURCE: Comfort Glow Vent-free Gas Heater CGN18B
Check with Ebay seller s.a.w.inc for available thermocouples. If that doesn't solve the problem the valve unit will likely need replaced.
Anonymous
  • 4 Answers
  • Posted on Nov 01, 2009
SOURCE: Can you vent the Rinnai 551F vertically through ceiling?
This unit can be vented through the roof but requires a specialized flue system-do not use an existing flue connection. Call a contractor - have them check and see if the unit can be modified to a vertical flue- it will require the existing piping to be replaced--Not a job for a do-it yourselfer
Anonymous
  • 79 Answers
  • Posted on Nov 29, 2009
SOURCE: empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Anonymous
  • 39 Answers
  • Posted on Dec 11, 2009
SOURCE: I have a Dyna-Glo vent-less wall mounted natural gas heater
If it is a few years old, it could be the thermocouple. These are usually available from Lowes. Take your model/serial # and if you can, take the old part too.
Anonymous
  • Posted on Mar 04, 2010
SOURCE: Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
Look behind the ceraminc logs chained to the burner frame. They are metal plates with instructions. That is how mine is.
I am looking to get new doors for this model, no luck looking online. Any ideas?
1helpful
1helpful
I need a thermo-coupler for a Temco wall heater. Model WC60-3
Contact a local small appliance repair business and they should be able to get you what you need.
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Do temco wall heater have a flame sensor
It more than likely has a bad thermocouple, it is the flame sensor. Some times if you move it a little bit closer to the pilot flame it will work. Also make sure there is no carbon or soot buildup .
Temco gas fireplace manual adl 36-1
where can I find a manual for a ADL 546-1 termco vent free gas fireplace. Really need your help as the township is requiring certification for these fireplaces. thanks
Jan 02, 2012 • Pool & Spa
Cant figure out how to relite my furnace
on the bottom of the unit there is an access door remove it and behind it you will find a gas valve and a pilot find the piolot......turn off the gas valve and move the selector to piolot depress the switch and at the same time place the flame from a log lighter onto the pilot light after this lights turn the gas valve to run and the burner should light.
4helpful
Need instructions on lighting a holly manufacturing company wall gas heater. I can't figure out what position is on for the main and pilot valves. Tried every position, but it won't light.
Where to buy replacement gasket for old gas wall heater: Narrowall Model Number - 350S-D Serial number - 3010 Holly Manufacturing Co.
Kenmore Dryer vent was plugged no heat now
No there is no manual reset on those dryer`s however, The most likely problem based on your description is the thermal fuse.
The thermal fuse is either located at the front or the back depending on the model number, but in any case it will be located on the exhaust housing and look`s like a small disc or thin pin shape ( see image below ) with 2 wires going to it and white in color.
c909e34.jpg If you can reply with an actual model number I can be more specific. This should move you forward though. Thank you for coming to "fixya" for your repair inquiries and good luck.
Please take a moment to rate the info I provided here for you today.
Thanks again,
macmarkus :)
2answers
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Top Heating & Cooling Experts
Paul Carew
john h
