Please check the manual at https://www.manualslib.com/manual/765327/Heartway-Medical-Products-Pt7.html#manual
SOURCE: 1967 BSA Seat Removal
buy a manual at bookstore or on line-the classic mc mags have tons of info-sorry i work on alot of pearl harbor iron
SOURCE: Replacing the battery on a mobility scooter
hi, ok remove the seat by turning it to the left, there is a lever normally on the right side that will allow it be turned round,
once you done that, lift the seat in a upwards motion, the cover should come away by gemerally lifting it, it should be attached by velco underneath,
you should now see two batteries. 40Ah batteries will allow you to go further if the battery Ah is lower, 50ah batteries again will allow you can go even further NOT faster, if you buy the larger AH batteries please make sure the dimensions of the batteries will fit within the scooter battery holders.
Regards
GeWiz.
Testimonial: "Thanks so much for the help. The seat did come off in the end but with difficulty. Batteries now changed OK. Thanks again. "
SOURCE: Where can I order parts for the drive medical
Hi is the on /off switch a proper key lock, or a round plug. If it is a round plug then the switch is probably a mono plug available from any radio repair shop. I have changed a few of these.
Is the name phantom a proper brand name, or just a name the importer put on it. Have a llok inside the covers and see if you can find another name, or a serial number sticker.
Good luck. Neil.
SOURCE: how to disconnect the back-up sound oon a medical drive falcon 4
Hi. On most scooters, the reverse beeper and the horn beeper noises are emitted from the same speaker.
The simplest way, is to unplug the speaker from the circuit board, although this might also disable the horn. It is easy to reconnect the beeper if you need to.
If you still need to use a horn, you can get cheap plastic ones from the bicycle shops.
Good luck. Neil.
Testimonial: "Thanks - hopefully, there are two wires to the speaker!"
SOURCE: Medical drive mobility scooter battery light flashing red after charge
http://www.wellalashes.com/3d-faux-mink-lashes-wholesale/ 3D Faux Mink Lashes Factory 3D Faux Mink Lashes Wholesale Silk Lashes China Vendor Wholesale 3D Faux Mink Lashes Factory Mink Eyelashes individuals mink eyelash with private packaging manufacturers.100% pure mink fur mink eyelash Hypo-allerganic,sterilized,no chemicals,no dyes,handcrafted . We can fast delivery and we can give you a big discount if you orde our mink eyelash.
Nothing in the manual about seat removal
