Heating & Cooling Logo
Herb Healy Posted on Nov 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a Reddy Heater Model RLP55V (variable 30-55,000 Btu. Will not stay lit when button is released, even after several minutes of operation. It is the thermocouple, the valve, relay, or what?
Bondedrepair
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 76 Answers
  • Posted on Nov 12, 2018
Bondedrepair
Expert
Level 2:
New Friend:
Night Owl:
Answers
76
Questions
0
Helped
35427
Points
175
If there is a brown copper line coming from gas valve is a thermol couple , and is bad when reinstalling don't over tighten it can damage the seat on the valve .
Vernon Taylor
Level 3:
  • Reddy Master 7,446 Answers
 Vernon Taylor
Reddy Master
Level 3:
Answers
7446
Questions
0
Helped
1955895
Points
26207
Possible the thermocouple bulb has slipped out of position and isn't being heated as it should. If it is a model with a pilot light, perhaps it is blocked.
The thermocouple is probably the most likely culprit.
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Mar 29, 2009
SOURCE: Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Anonymous
  • Posted on Jan 03, 2010
SOURCE: Reddy Heater will not stay lit
Thermocouple it going bad had same problem, you Should replace it.
Anonymous
  • 1476 Answers
  • Posted on Jul 30, 2010
SOURCE: L.P. Propane Heater not staying lit
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Anonymous
  • Posted on Jan 12, 2011
SOURCE: I have a PRO100 Reddy Heater would not stay lit
I had the same problem. Heater was propane with a long hose for movement.
I put the heater on my garage work bench and the thermocouple tested okay.
Tried to restart and it ran like a champ. Reassembled bottom panel, retested great.
When I set it on the floor, it went out! Hmmmm.
Restarted back on the benck. Great. No good on floor....Very cold (28 F) in the garage.
Think the propane might be going liquid in the hose...when heater hose has a "drip loop"
it works fine.
Maybe this is nuts, but it works keeping the heater up a bit on a STABLE surface.
Jim
Kens Repair
  • 67 Answers
  • Posted on Jan 19, 2011
SOURCE: replaced the thermocoupler on a propane reddy
Replace thermocoupler you tighten it to tight. Ken's Repair
Ignitor runs continually, even when lit....is this normal?...........turn the gas on and push the gas valve and lights perfect, but no matter how long you hold it in, when you release it, it will not stay...
This sounds like a problem with your thermocouple or flame rod. If it is a flame rod you may be able to just clean it with some sandpaper or steelwool. If it is a thermocouple you will probably need to replace it.
2answers
Flame won't stay lit
bobdukw,
This is a classic reddy heater problem. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
1helpful
2helpful
Reddy Heater won't stay lit
You dont need a tune up kit! If you replace the units thermostat and the unit will work like new again (this is why it keeps shutting off) This is a very common problem with this model.
Please rate this response and help us keep this area free!
Thank You!
1helpful
Won't stay lit..
I contacted ReddyParts.com and talked with their support department (866-883-9312). They instantly stated "your thermal coupler is bad". They had 1 in stock for 19.99 + shipping. I ordered it and plan to have it installed and tested by next weekend. The model I have is Reddy Heater Propane 35k to 55k (RLP55V).
Wont stay lit
Yep, sounds like you got it. Unscrew the fitting at the gas valve and take the thermocouple to a reputable Propane Gas supplier. They can match it up for you or you can order one off the internet.
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul Carew
vince
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
