Question about Frigidaire Freezers
Fridgidaire model #fffu14f2qwa freezer compressor won't come on
Compressor quit running
A special thanks to Assignment Help Australia for providing an exceptional assignment within a short period of time. Your work is really amazing. Hope you reach heights in the future. You can email us at cs@Myassignmenthelpau.Com or Phone Number: +61-2-8005-8227 My Assignment Help Australia
Posted on Feb 22, 2019
    Top Expert:
  • Frigidaire Master
  • 6,289 Answers
Most likely a thermostat problem if compressor isn’t running at all.
Posted on Dec 21, 2018
    Top Expert:
  • Frigidaire Master
  • 63,044 Answers
Call a repair service or go buy a new one
Posted on Nov 12, 2018
SOURCE:
22yooper
  • 828 Answers
SOURCE: Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Posted on Jul 06, 2008
  • 31 Answers
SOURCE: freezer compressor running, but no cooling
If the compressor is running and there's no cooling, chances are you have a sealed system leak somewhere. Meaning the machine has lost it's refrigerant charge. Pretty much need a set of gages at this point and start checking for potential leaks.
Posted on Mar 14, 2009
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: food thawing in freezer
You may have a small leak in the evaporator. You could try to get a replacement freon with stop leak from the automotive store and give it a shot. If it is a R12 unit then it is too old to repair. But it is worth the gamble to shoot it with freeze 12 or an equivilent before you condemn it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 11, 2009
buddymcl777
  • 67 Answers
SOURCE: Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Posted on May 01, 2009
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Freeezer with no compressor activity
If all fans are running, but not compressor You could try to install 3 N 1 start kit, thats might help 50/50. If it will start compressor - be ready for compressor to go out soon. might work for a year.
Dec 13, 2009 | Kenmore Freezers
New Commercial True Freezer suddenly quit freezing
Check for freon leak>> is compressor running?
or Iced over?
Jan 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Fridgidaire upright freezer alarm FFU2065FW
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one of these:
The compressor,The Thermostat,The overload, relay, or capacitor,The defrost timer,The condenser fan motor.
Try to troubleshoot each of these componet one after the other using eliminating method.
That may solve your problem.
Jul 23, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer won't run
Jul 01, 2008 | Freezers
Whirlpool ev200nxr upright freezer not cooling.
It is most likely the relay and overload or the thermostat.  What is the complete model # on the sticker inside the freezer?
Oct 15, 2007 | Freezers
Freezers Logo
269 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
