SOURCE: changing home thermostat
Couldn't find your thermostat based off the information you provided; find the model number and follow the link to the Contractor Support Page.
White-Rodgers Multi-Stage Thermostate Diagrams for Contractors
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
SOURCE: I need instructions for programming a Blue
Page 7 Programming
visit this website Link: http://www.emersonclimate.com/Documents/White-Rodgers/0037-6753.pdf
If you need futher help call hometechline 18002842925.
SOURCE: Want to replace a White-Rodgers
Hi, heatman101
Here is a tip that explains the wiring and the color designations...
Thermostat Wiring and Terminal Designations
Thermostat Problems - How to Change the Thermostat for Heating or Cooling
Electronic Digital Multi-Stage Thermostat 1F83-261
