You've obviously checked battery strength, battery connection and volume settings for the dead mic...does the green transmit (RF) LED light when you turn the mic on? Does the red audio (AF) LED light when you talk into the mic? Best solution....buy a better quality wireless system ($85 wireless?!? ...no thanks).
Pyle PLCM7300BT Mobile Video Navigations Back up Camera Rear View...
Went to this site to find your particular product,it has a downloadable pdf manual whic will by default show you your setup.You may not have the green wire but if you read this manual you may be able to by process of elimination figure out your question.Pyle also has a very good technical support staff,been there done that ,they will also help you out.Good luck hope this helps you.
The green wire connects to the backup lights control. When the gear shift is in "Reverse" this acts as the switch on the "Monitor" and turns the system on so you can see what's behind you to safely "Backup" Hope this helps you.
only step that is missing is the red wire one the camera.Use the adapter that is in the kit and attach it to your back-up lights this is used for your night LED's
