The separate flavors only meet at the center draw valve of the freezer door. That valve should have an H-type seal that looks like 2 connected o rings. If you haven't replaced this seal
034698 Large Basket Seal, it could be the problem. You can buy the seal individually or as part of a kit.
You can also try to make sure that the viscosity of the product is even, you don't want one side to be noticeably softer than the other.
The other possibility is there is a problem with the mix pumps. First try replacing all of the seals and gaskets. Use this kit
X49463 81Tune up kit for Taylor C712. The pump parts do wear out over time including the stainless steel cylinder sleeve. If one pump was working better than the other, that could explain the mix bleeding.
If none of that takes care of the problem let me know.
[email protected]
