It may be just a stuck relay on the control board, which I can repair for you.
feel free to contact me directly, and be sure to remind me of the full model number from the tag on your unit and your symptoms.
Ed Miller
[email protected]
MicrowaveControl.com
SOURCE: After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
SOURCE: microwave door ...hwhen closed....oven light and fan will turn on
This
is usually caused by either a bad door switch or a loose door switch
mount (which are pretty simple problems to fix).
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
We have uploaded the R1480 service manual to our site here to help you.
If yours is a different model, please reply back.
The best place to order
Sharp parts is Tritronics.
You can also call them at
866-779-5835.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: Microwave won't function.
This
is usually caused by either a bad door switch, a loose door switch
mount (which are pretty simple problems to fix) or
occasionally a
problem on the control panel.
Even though a door
switch clicks, it may still be bad inside.
Door switch
the
There are
The screws on these
activated properly.
Sometimes it's
know decide to look
FixYa:.
Also see http://www.microwavedisplay.com/doorsw.txt
You can usually find
exploded views and order parts by entering your model number at the Sears
parts site.
A full Sears/Kenmore
model number has 3 digits, a dot, then 8 more digits, such as
There
may also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases.
We're
SOURCE: microwave oven, ge profile model
This is usually caused by either a bad door switch, a loose door switch mount, or bad door hinge alignment.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. Other times, it's a broken tab on the switch
holder, allowing the switch to rotate just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or
handle as you try to start it. If it works or tries to work, then it's
a door switch mount or door alignment issue.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also
be a "mini-manual" hidden inside the unit behind the control panel or
hidden on the left side behind the grille, which is very helpful when
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Open Microwave Door and Fan comes on
Usually this is a problem with the door switches or a broken door switch mount. Sometimes after a part replacement one will find a couple of wires have been reversed. There should be a mini-manual with wiring diagram inside the oven behind the control panel. If those are all correct, you may have a problem with the control panel, which we repair nationwide for $39.95. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
