The tachometer or tacho-generator has the function of controlling the electric motor and the speed of the motor (rpm). So, could be electric motor blocked for some reason, worn out carbon brushes, faulty tachometer, wiring and finally electronic.
After 5 years working of washing machine, by my experience the most common reason is worn out the brushes of electric motor.
Dado
Dear Aung Ko Ko Min,
From my long-standing practice and according to the electronics manufacturer's recommendations that those in household appliances do not repair. Why is that so? Because it requires knowledge of a new area such as electronic components and can be very dangerous if inappropriate equivalents are used which can result in a fire or electric shock. My advice is cautious with electronics repair only with the assistance of a qualified person who knows what he is doing.
Dado
SOURCE: I have an Electrolux pw9 washingmachine which is showing error 13 what is the remedy
try the pump.....may need unblocking........
cheers
Fast stage. My controll have a shock circuit..So we made checking.we find 30N60 transistor 2pcs are opening.So we changed this transistors but we have 30N120 .So we made change 30N120 and than we made test run.All ok ;but have a showing display tacho earror .So we made a fault ?Transistor 30N120 2pcs changing ? Please you answer me.Thankyou.
