Pyle PLTDAND72 black screen and no sound from CD player
SOURCE: DIBOSS tv shows no picture
Me too! Apparently Diboss are no longer trading, so no help there. I am aware that these panels have a common power supply issue, the faulty chip is only available from China and the last one I fitted only lastest a couple of days. However the fault described above is not the same. I've checked the psu outputs; all are fine and nothing changes when the picture disappears, therefore I can assume that I'm not looking at a PSU fault. As Iain says above, it appears to be a signal link, however I have no picture on ANY input and without circuit diagrams I cannot find any component that's common to all the various inputs. This leads me to think that either the backlight, or the screen itself is faulty. I'll keep trying and if I get it sorted I will report back.
Jon
SOURCE: 6 dsc changer stock radio 99 ford explorer cddj error
I've had GREAT success by resetting the changer. Try unpluging the changer with the power ON, wait a few, then plug back in. It's not hard to remove. Can I assume that you did NOT misload or install any CD' upside down? If not, then proceed with a reset. Can you eject the magazine? If so, proceed with reset. If you can NOT eject the magazine, then you will need to "open up the can" and do a manual eject with power assist by moving the gears while pushing the eject button. Sounds like a lot, but for me it's easy. Remember patience!!
Larry T
Winona Lae, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
SOURCE: cd player reads err on display
internal problem in radio,you would have to take it to a dealer to send out for you,
SOURCE: my kodak ev1011 pic frame stopped working
You may try the online troubleshooting guide at www.kodak.com/go/itg and if it does not resolve the issue at the end of the guide you can fill out a form to send the frame for repair and also just an FYI the frame is warranty for one year and you must a copy of your receipt before sending the frame.
