Fallout 3 freezing is an unfortunately common problem. A lot of people have reported that clearing the game cache on your 360 will fix it, so that's what I would suggest you try first.
To do this:
- start up your 360, then take out the Fallout 3 game disc.
- Hold down the A button on the Player 1 controller
- Put Fallout 3 in your 360, then load the game
If this doesn't fix it, the next thing you could try is to clear the system cache. This will clear the entire cache for your 360, including the automatic updates (though downloaded content, save files, and user dats will be untouched).
To do this:
- Navigate to System > Memory
- Highlight the hard disk in the list and press Y
- Press X, X, LB, RB, X, X
If done right, you should see a message asking, "perform system maintenance?" Proceed with this, and it will clear all the cache data out and revert Fallout 3 back to version 1.0 (it should ask you to update once you load the game)
Hope this helps - I've had my share of frustration with Fallout 3 glitches.
-Nick F.
