SOURCE: msi wind l1350d Where is the
Depending upon the model it could be on the bottom of the laptop or under the keyboard.
SOURCE: msi l1350d web cam wont
Press the F6 Button - this will install the webcam driver. Give it a few seconds untill the "Device Driver Installed Successfully" message comes up, and the camera should work
SOURCE: while doing video call getting alert webcam not
MSI states that "This device uses the native driver bundled in operating system."But the driver may become corrupt, so you'll need to remove it first then re-discover it. To do so, follow these instructions
Go to Start\Control Panel\System and Security\Device Manager
Go to Imaging Devices, you should see the camera there. Right click the name of your camera and choose uninstall. After it gets deleted, go for
Action\Scan for hardware changes. It should discover your camera automatically.
If it still doesn't work, check your video calling application for video camera setup.
SOURCE: I have a MSI laptop computer model L1350D and I am
Press and hold the Fn button, and then press the F11 button to enable or disable the Wireless LAN/Bluetooth/3G/WiMax function.
Testimonial: "Very Good Help. Thanks"
SOURCE: how do i get my
Hi, I'm Naldz . If your web cam is new, there is a small disk that goes along with the package. Use this mini disk to install the driver that your computer needs in order for your web cam to work properly with your netbook computer. I hope this would solve your problem.. Have a good day !
