A lot of cause .... first, looks if the drain pump is working well and if it is not stuck or faulty
Seems to be working good.
I checked drain pump and seems to be draining. Only a cup of water in the bottom. Replace thermostat, water inlet valve, and motherboard. After flipped breaker back on the air dry and high temp wash lights blinking.
SOURCE: Fills with water, sounds like it starts to pump water then stops, then start again
you have a wash pump problem. can be 1 of 3 things. most likely something is caught in the pump impelor if not the wash pump motor may be faulty or ceized or it could be the capacitor for the wash pump motor is faulty. you can try removing the wash pump yourself and check the impelor if it spins freely then you will have a motor problem.
hope this helped
SOURCE: Dishwasher Heating element not working
my wife shut the water off to the dishwasher and forgot to turn it back on and then used the dishwasher.
the heating element went on but there was nop water.
when we turned the water back on,the drying cycle does not work.i would think that the element needs to be changed or is there a relay on the computer board?
this is a two year old Jennair unit.
any suggestions?
SOURCE: Kenmore Dryer Model 110 Heating Element & Thermostat
believe that model has a relay under console..pull console end caps off remove screw on each end roll console back..if your model has an electronic bd it also has a heat relay it will be the one with 2 large red wires.. a quick ck would be to unplug power remove the red wires and tape bear ends together pug back up turn on dryer if it heats unplug and exchange the 2 relays the one with the blue wires is the motor relay and is same as heat relay try again if motor fails to start bad relay if motor starts bad control bd
SOURCE: I have a G656 SCi Miele Dishwasher and the water
Probably the heater relay - do you have any fault codes?
SOURCE: Whirlpool dishwasher heating element overheating
Same thing just happened to my yesterday on my Kenmore. Expert help needed.
Hello preslncon - The black button that you are referring to is more than likely the Hi-Limit Thermostat. The Hi-Limit Thermostat will open and stop power from reaching the heating element. The Hi-Limit is not resettable, and if it is open, it would need replacing. As far as the burnt wire on the Thermostat, more than likely a loose connection to the Thermostat could have possibly caused the wire to overheat. This is not a typical do it yourself job. Personally, I would recommend reaching out to a qualified appliance repair person to proceed further. I hope this information helps to some degree.
