SOURCE: Cybershot camera not reading the memory stick
Have you tried reformatting your memory card itself?
SOURCE: Saving pictures
The camera has a very limited storage space on itself. It probably isnt saving the pictures on the card because the card is write protected (probably on accident)
just pull out the card and on it is a tiny little switch. just push that into the next position and it is no longer write protected. the write protection is there to prevent you from losing your photos, to put more photos on it you will have to deactive the protection with that switch, its usually white colored
SOURCE: screen reading memory card not initialized
help me i also have the same problem please email me how you fixed the problem? [email protected]
mahalo's
SOURCE: save from internal memory to memory card?
On play mode, press MENU, on PLAY tab-->COPY-->BUILD-IN->CARD, press SET,then wait until the "Busy...Please wait.. disappears.
SOURCE: My pictures are now replaced with a question mark.
sir the only problem that i can see is probably that your phone can not open large resolution images....try sending it to some other phone model or copying them onto a computer and then viewing them.I think you should be able to see them......please let me know if this doesn`t work.,,
