Question about Sunbeam Food Mixers
Turntable won't turn on sunbeam mixmaster stand mixer. Bowl hooks onto turntable but no movement
5 Suggested Answers
SOURCE:
ricardok45
  • 135 Answers
SOURCE: My sunbeam mixmasters turntable is not turning
Hi Jill. Your mixer's gears are made of plastic and can't really handle heavy loads such as cookie and bread doughs. Contact Sunbeam Corp. to locate a parts place near you. You'll need to replace at least the large gear that turns the turntable base, possibly the worm gear that turns the large gear too. Grease these gears when you re-install the parts. You'll have to cut a couple of cable ties to get the machine apart enough to do the work. If this solution has assisted you, please rate it. Good luck! ricardok45.
Posted on Mar 16, 2009
SOURCE: Turntable does not turn. Motor runs. Beaters work.
I have the same one, and the turn table has never turned on it's own. from looking at the bottom of the stand, i think the mixers are supposed to turn the bowl, so i just give it a little turn, and the mixers kinda take care of the rest. BTW, i got 2 sets of beaters with mine and i dont know what the second set is for, do you? contact me at rawemo@hotmail.com
Posted on Dec 18, 2010
SOURCE: Mixer on my Sunbeam Model
Where can I get brushes for a mmb mixmaster mixer
Posted on May 08, 2013
emissionwiz
  • 85160 Answers
SOURCE: will a sunbeam Mixmaster Stand Mixers Whisk fit a rival 12 speed stand mixer model FPRVSM0001 ?
Sorry we have no way to look this up.
Posted on Feb 10, 2017
Where do I get replacement bearings for a mixmaster turntable?
You can look at Nelsonezy, they have a good selection of mixer repair parts. NelsonEZY com home page
Dec 07, 2012 | Sunbeam 2386 MixMaster Series Stand Mixer
Bowl does not rotate anymore
This is typical of Sunbeam mixers. The solution is to throw that piece of junk out and never buy anything from Sunbeam again. They can't stand behind their products because they know they are junk. They would go out of business if they tried to repair/replace all of the useless appliances they sell.
Oct 24, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Bowl wont rotate
Mixer on my Sunbeam Model MX5900 compact mixmaster has burned out because beaters kept jambing in each other. Can I purchase just the mixer and beaters? Stand and bowl are OK
If the motors had burnt out then the winding can be redone if you can get this job to a winding shop.
Other wise the motor and assmebly can be ordered from a Sunbeam service outlet. try and see if you re able to source a motor assembly from a damaged/scrapped set with a mechanical defect.
Sep 20, 2011 | Sunbeam Food Mixers
My Sunbeam mixmaster bowl won't turn, how can I fix this?
I believe that this particular model is supposed to have the bowl mix separately. I have removed the black piece from the bottom of the larger bowl in order to allow manual spinning. If I am able to figure out how to fix the bowl spinner I will make another post.
Mar 06, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Why does my sunbean mixmaster bowl don't spin?
the spinning plate under the bowl does not have any power to spin the bowl; it only aks as a "lazy susan" carousel that allows the bowl to turn from the movement of the material being wipped in the bowl.
the beaters are purposely off-center of the bowl in ordwer to create a dragging motion of the material in the bowl, thus pulling (that is, spinning) the bowl slowly. If the beaters are not off to the side of the bowl, you will not get the pulling/spinning motion. Also, if the plate under the bowl does not move very easily, then the bowl will not spin. You may have to remove the spin plate and clean the center pivot for the plate to move freely. Good Luck, Macgivor.
Nov 27, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Hello, I have sunbeam mixer model #2360 and had one large and one small turntable. I lost the large turntable and am unable to locate a site to purchase another one. Can you please help? Thanks, so much!
Sunbeam 2386 Sunbeam 2386 MixMaster Series 275 Watts Stand Mixer. Overall User Rating. 3.0. out of 5 ... 2386 Reviews & Articles. Sunbeam - Small Appliance Parts ... retrevo.com/s/Sunbeam-2386-review-manual/id/952ci071/t/1-2
Good luck_Ned_
Nov 03, 2009 | Sunbeam 2386 MixMaster Series Stand Mixer
Feb 18, 2009 | Sunbeam Food Mixers
Food Mixers Logo
456 people viewed this question
Top Sunbeam Food Mixers Experts
Vincent G
Vincent G
Bruce Showalter
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
