SOURCE: Setup Wizard
check on the back of the unit there should be a reset, mine has a small pinhole for a paperclip
SOURCE: Can not connect to the internet in trying to setup the router.
Yes time warner is a cable connection and they dont require a username and pasword. You can set up the router manually by accessing its set up page. By default the router's IP is 192.168.2.1. Make sure to set the wan connection type to dynamic, change the wan mac address or clone your pc's mac. Then save the settings. Check your internet connection.
SOURCE: facebook Login Problem
I have tried to re set my password, they e mailed me and told me to click on it and follow the site.It won't let me do this so I tried to copy and paste but I don't know where to find the"browser" Can you please help?
SOURCE: When i type in the default username for the
To pull this off easy I would first unplug the system and allow it to sit about 2-3 minutes. this will give enough time for who ever is on your router to be kicked off. then I would plug in to the router via a direct connection. This will allow you to connect prior to anyone else picking up your source. Prior to unpluging it press and hold the reset button about 10-15 seconds. This will reset the system to fully reset to all factory default settings. This is also for the fact that whoever was on the net may have changed the password to keep you out. After connecting and resetting the router you should be able to log on and change the settings. Please rate this as a FIXYA if this solves your problem.
SOURCE: I have a di 624.
This is normal. Unless you have set it otherwise, the default username is admin, with no password.
Re-run the Setup Wizard using one of the following methods if you are unable to browse the Internet:
Re-run the HomePortal Setup Wizard from the HomePortal CD.
Re-run the HomePortal Setup Wizard by going to http://homeportal/setup (http://172.16.0.1/setup) in your Web browser.
(For Windows only.) Re-run the HomePortal Setup Wizard by clicking Start > Programs > 2Wire Gateway > Run 2Wire Setup Wizard.
