Tablets & eReaders Logo
C
Carol stewart Posted on Nov 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have bell email how do I set it up on my ipad
Ray
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Nov 13, 2018
Ray
Expert
Level 2:
Sergeant:
Answers
324
Questions
Helped
68546
Points
727
Emails keep being deleted off ipad air
It is in the settings to delete after a number of emails have been read . You can change the number of emails and set a time limit for the iPad to keep your mail.
I have try to make space on my I pad but I can't get my emails back
If you have set up your email account as an IMAP account, your emails are on the server, but if you delete them on your iPad, they are also delete on the server.
if you have set up your email account as a POP3 account, your emails are downloaded to your iPad ... if you delete them on your iPad, they are still on the server, so you can retrieve them. However, POP3 accounts don't show you the email folders that are on the server. You need to decide which is more important to you. On the iPad, do you want privacy (POP3) or flexibility (IMAP).
A POP3 account will also continue to use up more space (memory) and not clean-up (clear) ... eventually, you will have to delete the account to try to minimize the amount of used space. I don't know why it does this, but I have been fighting this problem for 4 years on two different versions of the iPhone. My iPhone is setup as POP3, while my iPad is set up as IMAP. I have not found a good answer to this problem.
2answers
Can't access email on my ipad
Go to Settings , then check you email app's settings.
If you don't find a problem ...
Delete your email app, then reinstall it.
2answers
How do I get my emails to show on my iPad as well as my laptop?
You need to go to Settings / Mail... etc / then create an account using your email details and those provided by your email supplier .. eg your ISP or Gmail etc.
You should set it up as an IMAP account to then replicate your Laptop email.
2answers
No sound on ipad
1. If you have no sound at all, even in the Music App, try rebooting the iPad.
Reboot the iPad by holding down on the sleep and home buttons at the same time for about 10-15 seconds until the Apple Logo appears - ignore the red slider if it appears on the screen - let go of the buttons. Let the iPad start up.
2. If you lost sounds for keyboard clicks, games or other apps, email notifications and other notifications, system sounds may have been muted.
System sounds can be muted and controlled two different ways. The screen lock rotation can be controlled in the same manner as well.
Settings>General>Use Side Switch to: Mute System sounds. If this option is selected, the switch on the side of the iPad above the volume rocker will mute system sounds.
If you choose Lock Screen Rotation, then the switch locks the screen. If the screen is locked, you will see a lock icon in the upper right corner next to the battery indicator gauge.
If you have the side switch set to lock screen rotation then the system sound control is in the control center. Swipe up from the bottom of the screen to get to control center . Tap on the bell icon and system sounds will return.
If you have the side switch set to mute system sounds, then the screen lock can be accessed in the same manner as described above.
This support article from Apple explains how the side switch works.
http://support.apple.com/kb/HT4085
3. Try cleaning the dock connector opening of the iPad with a soft brush and just a little bit of rubbing alcohol.
4. Reset all settings. Settings>General>Reset>Reset All Settings.
My iPad keeps downloading all message when I go in to it
Check your Mail account setting in Settings. Make sure folders are mapped properly to your e-mail account folders.
Nexicom.net email setup on ipad
You have to go into Settings -> Mail, calendar ... and add a new mail account as "Other". Put in your email address anywhere you see user name. Choose the POP type of account - IMAP won't work. Use the following for settings:
  • incoming server: mail.nexicom.net
  • user: your email full address
  • password: your password
  • outgoing server: outgoing.nexicom.net
  • user: your full email address
Tap "Next" and it will likely fail and ask if you want to connect without SSL. Tap "Yes" and you should get all green checkmarks and mail should now work. :v)
How do I set up my work email on the ipad
Does your work email supports a POP3 or IMAP settings?..I fyou do you just need to know what is the incoming mail server and outgoing mil server. Do not forget to ask for the ports needed in order for the settings to work with your ipad.
2helpful
Syncing Outlook 2007 email with iPad
You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
