Tools & Hardware - Others Logo
A
Annette Krueger Posted on Nov 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm looking for manual for the following product?
Polishing rotary tool wheel accessory kit meter 349pcs
john h
Level 3:
Top Expert:
  • Rotary Master 29,494 Answers
  • Posted on Nov 09, 2018
john h
Rotary Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559657
Points
193449
Check with manufacturer or online search using make and model
5 Related Answers
Anonymous
  • 1015 Answers
  • Posted on Sep 20, 2009
SOURCE: dont have a manual an the accessory kit for a
www.evga.com
Anonymous
  • 2176 Answers
  • Posted on Oct 03, 2009
SOURCE: Kawasaki Rotary Tool is missing the square collet nut
I am working on getting a website for this company, but you can try Alltradetools.com and see if they have anything, they distribute them.
Anonymous
  • 25 Answers
  • Posted on Sep 30, 2010
SOURCE: Where can I find a
I found this online..... www.ereplacementparts.com/images/ryobi/HT230.pdf
See if this will help
puertobori
  • 7733 Answers
  • Posted on Nov 17, 2010
SOURCE: i need to know what the accessories are with my
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
wiccan8house
wiccan8thhouse
  • 49 Answers
  • Posted on Aug 16, 2012
SOURCE: how to use the rotacraft rc 18 variable speed mini rotary tool kit
I uploaded a manual for ya --
I hope it helps -- wicc --
http://www.mediafire.com/file/g9fs9a73j8n3482/RC-18_MANUAL.pdf
Can you tell me where I can find a Manuel for the hyper tough rotary tool accessory kit?
Jill Timm's class, The Amazing Dremel, into one blog post.
Bwahahahahahahah!!!
I did not take into account how many notes I took during the workshop. In fact, my table neighbor at the workshop teased me for two days on how many notes I took.
My plan is to split the information into three blog posts:
Please note that this post only focuses on what the bits look like and what they do. Oh, and the bits mentioned are the only ones that we used in the workshop - we didn't use any routing bits. Sorry.
That said, let's talk Dremel bits.
I think that one of the things that both attracted me and freaked me out about the Dremel was its huge buffet of accessories. The packages are labeled by use, but it still seemed like gibberish to me. Jill created the perfect environment for overcoming my Dremel fear.
You can read about my class in the following blog posts:
This post is in no way meant to replace the total awesomeness of taking Jill Timm's class. I benefited so much from hearing Jill's experiences and seeing her work in person. If I had bought a Dremel and experimented with it on my own, most likely I would have never tried it on the range of materials that we did in class.
Jill recently announced that she's taking her Dremel class on the road and would love to be scheduled by your group. I highly recommend the class if you have a chance to attend.
The main categories of bits, according to Dremel, include the following:
  1. Carving & Engraving
  2. Sanding
  3. Cutting
  4. Grinding & Sharpening
  5. Cleaning & Polishing
These categories are pretty consistent among other manufacturers of rotary tool accessories, so you can often find alternatives if you shop around. Carving & Engraving I used two different types of bits that fall into the carving & engraving category - diamond bits and high speed cutters.
Diamond Dremel bits
Diamond bits can be used with the following materials:
  • Aluminum
  • Bookboard
  • Ceramic tile
  • Glass
  • Mirror
  • Steel
Dremel high speed cutters
High speed cutters can be used with the following materials:
  • Bookboard
  • Linoleum
  • Polymer clay
  • Wood
Sanding Sanding involves two different parts - the drum and the sanding band. Sanding bands come in different grits, just like sheets of sandpaper.
Dremel sanding bands and drum
To use the sanding band, you simply slide it over the drum. Replace it when it wears out. Easy peasy.
Sanding bits can be used with the following materials:
  • Aluminum
  • Bookboard
  • Plexiglass
  • Polymer clay
  • Wood
Cutting There are different types of cutting wheels for different materials.
Abrasive cutting wheels
Abrasive cutting wheels can be used with the following materials:
  • Bookboard
  • Plexiglass
  • Wood
Fiberglass cutting wheel
Fiberglass cutting wheels can be used with the following materials:
  • Aluminum
  • Bookboard
  • Ceramic tile
  • Wood
To use a cutting wheel, you have to attach it a mandrel.
Dremel mandrel
Unscrew the tiny screw on top of the mandrel and remove one of the washers.
Slide the wheel onto the screw, then add the second washer. Attach the screw to the mandrel base and tighten.
Replace the wheel it when it wears out.
Grinding & Sharpening Grinding and sharpening stones are made of two basic materials: silicon carbide (green bits) and aluminum oxide (brown, orange, pink, or grey bits). You may have noticed that some of my grinding stones are oddly-shaped. This is because the stones wear out with use. You can reshape your grinding stones using a dressing stone.
Orange grinding stones
Orange stones can be used with the following materials:
  • Ceramic tile
  • Glass
  • Mirror
  • Steel
Blue/green & pink grinding stones
Blue/green and pink stones can be used with the following materials:
  • Aluminum
  • Ceramic tile
  • Glass
  • Mirror
Cleaning & Polishing Felt polishing wheels and cones are used in combination with polishing compound.
Polishing felts and mandrel
Polishing compound
To use a polishing felt, you have to attach it a mandrel (different from the cutting wheel mandrel). The felt has a tiny hole in the center of it - you screw the mandrel into the hole to attach it.
Felt polishing wheels and cones can be used with the following materials:
  • Aluminum
  • Ceramic tile
  • Glass
  • Mirror
Rotary tool Model S1J-AJ2-10
Check the power coming in. Apply an ohm meter across the plug to see if you have continuity through the motor. We really need more information.
I have been given a durabuilt rotary tool but have no manual or instructions on how to use, and I can't even figure out how to change bits... is there a free or inexpensive manual that I can obtain?
WEN Products has a rotary tool that is very nearly an exact duplicate of the Durabuilt rotary tool. I use the WEN manual at home for my Durabuilt rotary tool.
If you would like to see the WEN product page for their rotary tool, please visit this link: http://www.wenproducts.com/store/101-Piece-Rotary-Tool-Kit-2307
Here is a direct link to download the manual: http://www.wenproducts.com/store/index.php?route=product/download/download&download_id=62
Sep 05, 2011 • Garden
I'm trying to install the felt polishing tip, and it's only a round piece of thick felt. How do I install it on my dremel?
there in the kit is a shaft with a screw tip on it, you need to thread the polishing disc on the shaft, the shaft has a threaded screw, not the internal type
I have bought a rotatry tool that came with accessories but I don't know which accessories to use for what job. It is hard to identify which accessory is what. Did not come with illustration of what each...
I assume you mean something like a Dremel high speed rotary tool with various bits. Here are some general guidelines....
You can divide the bits into three groups - cutting, grinding, and polishing.
The cutting tools will have the largest (relatively) teeth, some look like little gears. These are suitable for fairly soft materials like wood and plastic, and maybe drywall. They are useful for carving.
The grinding tools are either small stones (these are very hard, not rubber) or they have a fine coating of diamonds glued to a metal surface. Both are used for grinding hard stuff like metal, ceramics or glass. The diamond coated ones can grind very hard materials. The stone ones can wear down, but remain usable. Grinding is handy for sharpening and for removing small amounts of metal to shape it - but this is a pretty slow process. You can also etch glass by grinding it, but be sure to keep a little water on the glass or the local heating of the glass will break it.
The polishing tools are hard rubber or fabric or little wire brushes. These are good for polishing things, mostly metal. I find the little wire brush bits very useful for cleaning up corroded contacts in flashlights and other battery-operated devices.
Be sure to wear safety glasses with any of these bits, but especially the wire brushes as they tend to throw out those little wires!
Let me know if you would like any more help. Thanks for using Fixya, and good luck.
Al K
Cant get replacement brass cleaning wheels
harbor freight....they have all those things...a rotary grinder is a rotary grinder, they are all the same
Tasks usage
Cutting holes in wallboard, Removing grout, Deburring metal, Cutting fiberglass, Sanding in tight spots, Cutting the heads off stripped screws, Shaping metal, Cutting ceramic tile, Stripping old paint and varnish from woodwork, Removing window pane glazing, Grinding, Shaping and cutting in arts and crafts projects, Polishing metal, Engraving, Etching, Cutting marble, Cutting nails, Cutting plumbing pipe, Sharpening tools, Cutting wood.
Rotary tools Attachments
Flex Shaft, Sanding Disks, Polishing Pads, Metal Blades, Wire Brushes, Abrasive Brushes.
Top Rotary Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
