Coleman lantern charged but when I unplug from wall it won't light up.only when I replug into wall socket it lights up..so only works if staying plugged in wall socket?..
SOURCE: panasonic microwave no power or light
I must have suggested this 20 time today. if you open the casing you will find several fusees that the manufacturers don't want you to know about.
you have a 10 ampish large fuse that protects the power circuits ( transformer/magnatrons) smaller fuses for control circuits also might want to look atand reset the thermal cutouts. if it overheatedprior to failure
SOURCE: how to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
SOURCE: Headset indicates fully charged (green
The rechargeable battery is bad and needs to be replaced.
SOURCE: Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
