Reset doesn't work. Speakers don't make a sound.
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
SOURCE: No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
SOURCE: Speakers don work under Ubuntu 9.04 in presario cq61
ICEBOX - I had exactly the same problem! But I have just fixed it after several hours of pulling my hair out. I had tried everything I could think of, as well as lots of solutions other people had suggested, including installing the latest version if Alsa from source etc. Nothing worked, until I found these four lines on another forum. Simply paste them at the end of /etc/modules.d/alsa-base.conf and save it.
options snd slots=snd-hda-intel
options snd-hda-intel model=hp-m4
alias snd-card-0 snd-hda-intel
options snd-hda-intel enable_msi=1
Restart the computer and you should get sound out of the speakers as well as the headphone socket.
SOURCE: centre speaker not working on yamaha surround sound unit.
Check your "Setup" in the main menu of the receiver. Press "Menu" or "GUI" whichever you have on the remote and go to "Manual Setup" then toggle to "Audio" then "Speakers" then toggle to "Center Channel" and make sure it's on "Large" or "Small" instead of "None". If you still don't have audio, post a comment with the model # of your receiver, I'll pull the book and help you further. Hope this helps.
