SOURCE: fridge drain not clearing
Try clearing it a little better. Use some kind of pipe cleaner then flush with hot water. Good luck
SOURCE: Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
SOURCE: Liebherr k 2724 4 years
All you to do is to check on the control knob, this could be faulty or loosen , do replace if found faulty . this is the common problem that a refrigerator do have and replacing the control knob solve the problem .
Good luck......
SOURCE: Liebherr KBES 3650 - too
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
SOURCE: Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
