Here's a link to Yamaha year ID. You need the letter that is below the number you have given to get the year.
https://docs.google.com/document/d/1air2AFd0Nuodb_GdpEkBLYfNYF9KGQmv26spIZmFzIs/edit?usp=sharing
SOURCE: relay switch for power tilt for Johnson outboard motor 40HP
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
SOURCE: I need a maual for a Yamaha 85 hp outboard motor 1992 model?
Hello nic nic 68,
I know that a autozone will have the manual you are looking for. If you still need assistance please post again and i will gladly help.
Please post what you decide to do and how you do it.
I look forward to your posts.
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
SOURCE: need firing order for a 86 chrysler outboard boat engine
Firing order 1 2 3 is common on most three cylinder outboards. 1 3 2 is the only other combination.
