Question about Kohler Electrical Supplies
Kohler model 5EKD Auxiliary fault code,will only run for a few seconds, at manual start what is the cause?
  • Abdul Haq
    Abdul Haq Nov 14, 2018
    please check the coolant level if coolant level is ok then check the coolant level sensor and its wires may be any one wire is grounding.
2 Suggested Answers
SOURCE:
  • 512 Answers
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
Posted on Oct 08, 2012
Kohler 40EFOZD Auxiliary Lamp starts flashing After 2 minutes.
Make sure you have rated speed and voltage on the out put side.
Oct 13, 2014 | Kohler Electrical Supplies
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
WHAT IS THE MOST LIKELY CAUSE OF AN AUXILIARY FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Check radiator coolant fill right to the top, if it has a low level switch or faulty switch I have seen this
Kohler 12.5 res gen. Battery is good. Get OC code. If I reset auto switch by clicking off, then clicking run, then clicking auto it will start. Any thoughts on this issue?
OC is Over Crank which generally means it cranked and cranked and failed to start. Turning the switch off and on again is the way to clear the fault. How long is it taking to start whilst cranking? It should start within 8 seconds
Sep 11, 2013 | Kohler Electrical Supplies
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RES, 12.5kw genset. Less than a
check connections on speedsensor or take down rpms must be a screw or bolt on de fuelpump
Jan 25, 2010 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
202 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
