Please explain what your meaning of jet and express so I can help you better. LG refrigerators are hard to get parts for. But, I can help you. So I can help and will you look for the model listed above your post. Please confirm the model number, this is very important, Thanks, Sea Breeze
I had this same problem.. i just had to remove the key.. but to permantently stop i had to replace both door sensors.. because it was not sensing they were both shut then the light would stay on and the dinging would continue until i removed key and or fixed this... this may not be the problem but might help..
the dinging is from having the turn signal on to long it s a warning I know that sounds strange, mine did the same thing happen to me i made a turn but the turn signal didnt shut off couple mins. later i hear ding ding ding looked at dash turn signal was on shut it off it quit dinging. hope this helps
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Coolant that goes down, but is not leaking visibly (check for puddles after parking), is probably a head gasket problem. Have u been checking the oil level? Is it going up, or not using as much as before? This is usually an indication of a bad head gasket, which allows the coolant to leak into the oil. The ticking noise can actually be the head gasket also. As the vehicle warms up, things expand, and any leak in the head gasket will close up and the ticking noise will not be noticeable. As time goes on, the 'ticking' will last longer, and get worse. Have u noticed if this ticking is lasting longer than when u 1st heard it? Let me know how u make out. countrycurt0
