SOURCE: my dryer belt broke
i need a diagrame of how the belt goes on the drum . dryer is a roper 386567 3 cycle 2-384
SOURCE: 99 sl rattle in front when engine warms, not a rod knocking.
The solution is simple and easy, if not cheap.
You have a defective upper motor mount. If you open the hood and look for the motor mount on the left hand side near the accessory belt, you will notice that the rubber has shrunk. THAT is the problem.
This will only make noise at idle at a stoplight and doesn't do it all the time.
I have a 1999 Saturn SL and have fixed this problem once by replacing the motor mount. The first time, it was just out of warranty and only had about 60,000 miles on it. It has manifested itself again (started a while ago - now has 114,000 miles on it)
I am the only owner of the car and it is now 10 years old. I won't change it again unless they redesign the motor mount.
You can replace the motor mount yourself if you are somewhat handy - it will cost around $100 for the part if I recall correctly. Make sure you prop the motor up; it should take about 30-60 minutes.
SOURCE: Whirlpool Gas Dryer idler pulley assembly (# 691366)
pull the belt thru the ider not around it if you cant get it..post your email i will send you the guide on it along with your model number
SOURCE: idler pulley arm
there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.
SOURCE: Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
