Nontsikelelo Ntlomelwane Posted on Nov 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Iwant calculation with numbers for my quedtion calculate distabc sandton 5,3 km
DocZachary
Level 3:
Master:
  • Master 533 Answers
  • Posted on Nov 08, 2018
DocZachary
Master
Level 3:
Master:
Answers
533
Questions
Helped
167644
Points
2496
Huh? Try again. Not sure what you are asking.
Semper Fi,
Z
5 Related Answers
Neenieoregon
  • 6 Answers
  • Posted on Jan 30, 2008
SOURCE: my calculator has a funny format
Try pushing and releasing [f], then [4]. This will give you 4 decimal places. (It follows that if you want 5 decimal places, push 5 instead of 4, etc). If that doesn't work, you can try taking the batteries out and putting them back in which should reset it to 2 decimal places, then set it where you want it following the above.
If it continues to malfunction I suggest taking the batteries out for 24 hours to allow a static discharge. This will lose anything you stored in the calculator, setting it back to how it came from the factory.
Anonymous
  • Posted on Apr 20, 2008
SOURCE: FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Anonymous
  • 36 Answers
  • Posted on Jul 14, 2009
SOURCE: i dont know how to use the number pad as a calculator
On your keyboard, you will see a small button or symbol of a calculator. Press this button. The calculator should pop up on your screen and you'll be good to go.
Anonymous
  • Posted on Sep 20, 2009
SOURCE: How do I calculate the square root of a number on
enter the number, press 2nd and then press the button that has the squareroot and the x in the middle (beside the AC/ON button) for example, i have to find the square root of 25, i press 2nd and the button and i get 5, hoped this would help :-)
Anonymous
  • Posted on Apr 14, 2010
SOURCE: problem changing tax rate on casio calculator
Press AC twice. Hold down % set key for about 2 seconds until ?0? disappears on screen, then reappears. Press Tax Rate key. Input tax rate (12.5%) and press % set key.
The actual distance d varies directly as the distance s on a map. If 2 cm on a certain map represents 15 km find the actual distance represented by a distance of 70 cm on the map.
70 cm is 35 times larger than 2 cm so it represents a distance 35 times larger than 15 km, or 525 km.
Sorry I can't give you the exact keystroke sequence to calculate it as you didn't specify the make and model of your calculator.
3answers
Cannot calculate antilog value for negative numbers . Example: antilog(-5)
Make sure you use the (-) key to enter negative values, not the - key. For example, to calculate the common antilog of -5, press
SHIFT log (-) 5 =
To calculate the natural antilog of -5, press
SHIFT ln (-) 5 =
I am trying to divide a whole into a smaller number that is a decimal, any help? The question is 5 divide into o.45
You didn't specify the make and model of your calculator, so I can't give you an exact keystroke sequence.
The calculator doesn't care whether a number is a whole number or not. Just do the division.
On most algebraic-logic calculators, to divide 5 into 0.45, press . 4 5 / 5 =
On an RPN or RPL calculator, press . 4 5 ENTER 5 /
On most algebraic-logic calculators, to divide 5 by 0.45, press 5 / . 4 5 =
On an RPN or RPL calculator, press 5 ENTER . 4 5 /
If you still have problems, please reply to this post specifying the make and model of the calculator you're trying to use.
2helpful
How do you subtract fraction on a caluclator. problem: 6/7-2/5
A fraction is just a number like (almost) any other. On most calculators, as you enter 6/5 the calculator displays its decimal value. When you press - the calculator waits for a number 2 then / then 5. Once you press the equal sign it will calculate 2/5 then subtracts it from the preceding result. The priority rules favor multiplication and division over addition and subtraction.
On some calculators you can keep a fraction in fraction format and operate on it with other fractions, and the result may be obtained as a fraction.
The gist of the story is that ON A CALCULATOR operations on fractions as performed like operations on any number.
2answers
Factions
The fraction symbol is ab/c
All scientific/graphics calculators have a fraction key. Going by the picture I would assume that calculator would have it
10helpful
How do i calculate permutation in fx-82ms casio calculator
Find on the calculator the [nPr] key either (you may have to use the [2nd] or [2ndF] key) then
1. Enter the number that corresponds to n eg. 18
2. Press the [nPr] key
3. Enter the number that corresponds to r eg. 5
18[nPr]5 gives 1028160
If you calculate combinaitions use [nCr] key.
Hope it helps
k24674
ADMIN Andrew
ADMIN Andrew
