Everytime I hook up the Sansa e260 to the computer, a popup comes up saying "New Hardware Device Found!" but I can't seem to get it to install anything that will make it so Rhapsody (or any other player) recognizes the player. The player recognizes the computer and the computer recognizes the device, but the computer doesn't know what the device is or is supposed to do. I'm running windows 2000
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa )
Download the Sansa Recovery Tool for the Sansa e200 series and run the official Sansa Recovery Mode
or
Run Windows Recovery Mode
Try this: disconnect the player from the computer, turn it off, hold in the REC button, and reconnect the player to the computer while holding the REC button in. Keep holding the REC button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
Unplug the Sansa from the computer. Turn it off. Hold in the REC button. Reconnect the Sansa to the computer while holding in the REC button. After 10-15 seconds of continuing to hold in the REC button, a window should pop up saying "Found New Hardware Wizard." Complete the Wizard.
Substitute REC fo volume + in the following:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first.On most models, restart is done by holding the power button in for 15 seconds or longer.Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
I have guys, I just spoke with the Sansa representative. Even if you have Windows Vista, you do not need a drive for e260 given that Vista carries that drivers for it. If you have tried the steps above, but you Sansa still did not format successfully after using the recoverty tool. This is what you do:
Set you Sansa e260 in recovery mode
- set it to hold
- hold rec
- connect to computer while you are holding rec
- device should be now in recovrey mode
- go to my computer
- go to the folder 16B format
- you will see a text file
- don't worry about
- add a new folder and name Sansa.fmt
- wait up to 2 minutes
- message on your device should say formatting
- wait a few minutes for formatting to take place
- stop the device by removing it safely using windows Safely device removal tool on bottom right corner of your screen
- disconneting your Sansa and you should see a message upgrade finished, Sansa has been restored or something like that
- Power your Sansa on, and Bwala!!! your Sansa is back to normal.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
i need help to erase my music
