SOURCE: I have just installed the
YOu need to make sure that the maestro you installed is designed for use with electric motors. CHeck out this page on the lutron site... http://www.lutron.com/CMS400/page.aspx?id=16955&mn=1797. THese are the dimmers you can use with a fan. If it is in the same box the magnetic interference can cause the types of reactions you are mentioning.
If this is not the problem you need more info-- is the light part of the fan, is there a separate wire for fan motor and light? what type of switch is controlling the light (assuming the maestro dimmer is controlling the fan motor etc...
SOURCE: A fixture on a Lutron Maestro dimmer switch stopped working.
This dimmer was not made to dim a load smaller than 40VA. That halogen bulb would only have been 20VA or so.
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
I think that when your bulb burnt out, the dimmer over-volted the transformer and smoked it. That said, I think you have a fixture problem and, possibly, a switch problem, too.
SOURCE: Trying to hook up a Lutron fan control and dimmer
The old switch is just a single pole switch. The new one is for fan speed control. You need to use a regular single pole switch like you had. Or you can use a single pole switch on the Lutron you bought if you can figure out which wires to use. Do you have a meter?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Lutron Dimmer Not Dimming But On/Off Works
The type of track heads you are using could be creating the problem. Are the lamps Par 20, Par 30 (screw in base) or MR-16 low voltage (push in base)? If the track head has a small (2"x4") box and uses MR-16 lamps then you need to use a dimmer specifically designed for ELECTRONIC LOW VOLTAGE. Incandescent lights (screw in base) and Electronic low voltage need a different signal to dim. Using a standard dimmer for electronic low voltage will work for a while, but then either the dimmer or the fixtures will go bad. If your lamps are incandescent or halogen you may have just had a bad dimmer. (Not common for Lutron products) but the part number you list should be good for 1000watts and should not be the issue.
http://www.lutron.com/CMS400/TechInfoPage.aspx?id=25531
Please see "Dimming Basics" under the helpful information tab for a better explanations of the two different styles of dimming. Hope this helps!
SOURCE: 3-way dimmer dead
It could be a loose connection, and it could be a loose connection on the OTHER 3-way switch across the room. Also, verify that the dimmer is rated for the fixture(s): add together the wattage of each individual light bulb that the dimmer controls and make sure that the dimmer has a higher wattage rating. If it isn't, you might have burned up your dimmer (and risked an electrical fire). Hope this helps!
