SOURCE: Parrot CK3000 Evolution
after a reset try to push the parrot in pairing with your phone.< for any G3 phone the below should work. The menu could be differnet on yours this is for a nokia G3 phone. Object Push: * From your phone go to MENU / COMMUNIC. / CONTACTS * Select the desired contact to send * Go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / ALL CONTACT DATA * Phone will search for available bluetooth devices * Select from the list Parrot Product and press SELECT * wait until the contact is transferred. After contact is sent, it is neccessary to register "Contact's Name"
SOURCE: Unable to connect my iphone 3gs to the Parrot CK3000 Evolution.
You need to reset the Parrot first.
Hold down red and green buttons together until she tells you that the
memory is being cleared. Then she will prompt you to pair your phone.
Then, and only then does the Parrot allow the iPhone to pair, and it will bring up the code prompt for you on the iPhone.
You won't find this written down anywhere on the Parrot site.
SOURCE: My Nokio E52 'sees' the CK3000 Evol parrot, but will not connect.
Switched on the E52 the blue tooth option External SIM Modus to On and kept on trying. And then finally the phone asked for accepting the arrot connection. Entered 1234 and it worked.
SOURCE: Parrot Car Kit "no signal" detected problem
No signal is normally a result of the power wires been the wrong way round, disconnect the parrot, check memory and switched live are correct the try the unit again, if it still dont work then it will need new software hard wired into it. Find your nearest Parrot engineer from parrot.com
SOURCE: My Parrot ck3000 does not pair with nokia N97... I
Press and hold the red and green button to reset all prvious paired devices, then try again.
